15单片机串口2只能接受数据,不能发数据
613|0
 楼主| 码行天下 发表于 2017-5-17 20:53 | 显示全部楼层 |阅读模式
我已经用了串口1发送数据,波特率9600但没有用中断,串口2相关程序如下,现在问题是函数 Uart2_Sendstring("The bedroom light has been turned off.\r\n");不执行
void Uart2Init(void)                //9600
        S2CON = 0x50;                           //8位数据,可变波特率
        AUXR|= 0x04;                           //定时器2时钟为Fosc,即1T
        T2L = 0xE0;                             //设定定时初值
        T2H = 0xFE;                             //设定定时初值
        AUXR|= 0x10;                           //启动定时器2
        EA=1;
  IE2=IE2|0x01;
void Uart2_Sendstring(uchar *str)
    uchar *p;
          IE2=IE2&0xFE;
          S2CON=S2CON&0xFD;
    p = str;
    while(*p != '\0')
          S2BUF = *p;
                  while(S2CON&0x02== 0);      //等待发送标志位置位
                     S2CON=S2CON&0xFD;
         p++;
         IE2=IE2|0x01;
void BlueTooth_INT() interrupt 8
        uchar receivechar;    //接受的字符
        if(S2CON&0X01==1)
          S2CON=S2CON&0XFE;
          receivechar=S2BUF;
          switch(receivechar)
                        case '1':        //收到字符1,指示灯0灭
                                                          LED0=1;
                                  break;
                        case '2':        //收到字符2,指示灯1灭
        LED0=0;
        Uart2_Sendstring("The bedroom light has been turned on.\r\n");
                                  break;
      default:  //输入其他数据返回error
                                        Uart2_Sendstring("error\r\n");
                break;
void main()
         Uart2Init();
          while(1);
