[AVR单片机] 求教avr studio无法编译C程序
5815|5
 楼主| vb8088 发表于 2010-5-8 21:33 | 显示全部楼层 |阅读模式
我安装了winavr 与avr studio,在AVR STUDIO里写了C程序,按BUILD,总显示两个错误。
build窗口显示
      Build started 8.5.2010 at 20:42:42
make: Makefile: No such file or directory
make: *** NO rule to make target `Makefile'.  Stop.
Build failed with 2 errors and 0 warnings...。
  请那个高指点一下。我研究一天没有解决。
                                           谢谢。
                                                          VB8088
        2010.05.08
                                                          VB8088@126.COM
Karlshen 发表于 2010-5-9 08:53 | 显示全部楼层
I downloaded the latest version of axiom (but the following problem was there also with the previous version).
I compiled it correctly, even if with some "warning" every now and then.
When installing, I get:
address@bogus.example.com:/home/stumbo/tmp/axiom]# make install
78 installing Axiom in /usr/local/axiom
/bin/sh: line 1: /usr/local/axiom/mnt//bin/axiom: No such file or directory
make: *** [install] Error 1
If I create the directory:
address@bogus.example.com:/home/stumbo/tmp/axiom]# mkdir -p /usr/local/axiom/mnt/bin
then everything works fine:
Karlshen 发表于 2010-5-9 09:18 | 显示全部楼层
这个和你的问题很类似的出现的问题No such file or directory一样,设法改路径then everything works fine:
ytfdhb 发表于 2010-9-21 16:19 | 显示全部楼层
改一个include 路径和library的路径……
宇宙飞船 发表于 2010-9-21 21:02 | 显示全部楼层
建议楼主用winavr自带的PN编辑器,否则转型ARM时还得重新熟悉另外的编辑界面。
wadezyb 发表于 2010-10-13 01:18 | 显示全部楼层
我用的也是AVR STUDIO,只装一个不能编译C程序,还需要装winavr,才可以。还有如果还不好使,就把avrstudio卸了重装一遍,就好了
