[技术问题解答] 关于ke02配置外部时钟的问题
826|0
 楼主| diy2060 发表于 2017-5-28 23:09 | 显示全部楼层 |阅读模式
各位大哥好,我现用8m的外部晶振请问以下的配置对不对?
#if defined(TEST_ON_EVB)
    /*! define what clock mode at startup on EVB board
     * if USE_FEE is not defined by commenting out the following line,
     * then it will use FEI mode which is default mode
     * after reset
    #define USE_FEE                       /*!< use FEE clock mode */
    //#define USE_FEE_OSC                     /*!< use FEE clock mode with external active oscillator */
    //#define USE_FEI                       /*!< use FEI clock mode */
    /* define external crystal frequency */
    //#define EXT_CLK_FREQ_KHZ        32          /* in KHz */
    //#define EXT_CLK_FREQ_KHZ        4000        /* in KHz */
    #define EXT_CLK_FREQ_KHZ        8000        /* in KHz */
    //#define EXT_CLK_FREQ_KHZ        10000       /* in KHz */
    //#define CRYST_HIGH_GAIN
    //#define XOSC_STOP_ENABLE
    /* define SCI port # to be used */
    #define TERM_PORT   UART0               /*!< UART0 is used on KE02 EVB board */
#else
    /*! define what clock mode at startup on freedom board
     * after reset.
    /*! define external crystal frequency. */
    /*! define UART port # to be used */
    #define TERM_PORT   UART1               /*!< UART1 is used on KE02 freedom board */
#endif
