Input Formatter
Features
Supports 24-bit/16-bit/8-bit digital input
Supports various RGB and YCrCb input data formats
Supports for input resolutions of 720×480 and 720×576 in interlace or progressive mode
Supports ITU-R BT.601/656 standard input
Brightness, contrast and saturation adjustable
Fully programmed through a serial port
Output Formatter
High quality 10-bit triple-DAC
Supports analog AV and S-Video output
Supports formats NTSC-M, NTSC-J, NTSC-433, PAL-B/D/G/H/I, PAL-M, PAL-N and PAL-60
Supports hot plug detection
2-wire I2C Slave Interface Package
TQFP -48 plastic(7mm×7mm)
PB-free and RoHS compliant
王先生:18856951639,QQ:1028390251,skype:roc_wang149 |
