| 步入正题,代码如下: #include<reg52.h>
 #include <stdlib.h>
 #include <intrins.h>
 #define uchar unsigned char
 #define uint unsigned int
 #define LCD_data P0
 sbit col1=P1^7;   //列端口定义
 sbit col2=P1^6;
 sbit col3=P2^0;
 sbit col4=P2^1;
 sbit LCD_EN=P3^4;
 sbit LCD_RS=P3^5;
 sbit LCD_RW=P3^6;
 sbit LCD_PSB=P3^7;
 uchar code dis0[]={"****智能控制****"};
 uchar code dis1[]={"当前功能显示区"};
 uchar code dis2[]={"当前水温:"};
 uchar code dis3[]={"当前水位比: 50%"};
 uchar code dis4[]={"按S17 开始上水"};
 uchar code dis5[]={"目标水位比: 50%"};
 uchar code dis6[]={"按 S5 停止上水"};
 uchar code dis7[]={"上水中..."};
 uchar code dis8[]={"按S18 开始加热"};
 uchar code dis9[]={"目标水温:"};
 uchar code dis10[]={"按 S6 停止加热"};
 uchar code dis11[]={"加热中..."};
 uchar code dis12[][10]={"51%","52%","53%","54%","55%","56%","57%","58%","59%","60%", //0-9
 "61%","62%","63%","64%","65%","66%","67%","68%","69%","70%", //10-19
 "71%","72%","73%","74%","75%","76%","77%","78%","79%","80%", //20-29
 "81%","82%","83%","84%","85%","86%","87%","88%","89%","90%", //30-39
 "91%","92%","93%","94%","95%","96%","97%","98%","99%","100%"};//40-49
 uchar code dis13[][10]={"49%","48%","47%","46%","45%","44%","43%","42%","41%","40%",//0-9
 "39%","38%","37%","36%","35%","34%","33%","32%","31%","30%"};//10-19
 /*uchar code dis12[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
 0x00,0x00,0x00,0x00};//清行*/
 void delay1ms(uint);
 void dekay(uchar);
 void keyscan();
 void write_cmd(uchar cmd);
 void write_dat(uchar dat);
 void lcd_pos(uchar X,uchar Y);
 void lcd_init();
 uchar num,i,m,n,temp;
 uint counter,a,counter1,b;
 uint add0;
 void main()//固定界面显示
 //uint add0,add1,minus0,minus1;
 delay1ms(10);
 lcd_init();
 lcd_pos(0,0);//智能控制
 i=0;
 while(dis0!='\0')
 write_dat(dis0);
 i++;
 lcd_pos(1,0);//当前水温
 i=0;
 while(dis2!='\0')
 write_dat(dis2);
 i++;
 lcd_pos(2,0);//当前水位比
 i=0;
 while(dis3!='\0')
 write_dat(dis3);
 i++;
 lcd_pos(3,0);//当前功能显示区
 i=0;
 while(dis1!='\0')
 write_dat(dis1);
 i++;
 delay1ms(10);
 while(1)
 //P1=0xff;
 //P2=0xff;
 //P3=0xff;
 keyscan();
 void delay1ms(uint x)//延时
 uint i,j;
 for(j=0;j<x;j++)
 for(i=0;i<110;i++);
 void delay(uchar i)//延时
 uchar j,k;
 for(j=i;j>0;j--)
 for(k=125;k>0;k--);
