[技术求助] 计算过程
570|5
 楼主| lizye 发表于 2017-6-9 22:40 | 显示全部楼层 |阅读模式
我现在用的是5502的板子,在板上UARTONCHIP测试程序中,GPT_Config  MyGptConfig {0,0,0,0,0,0x56c4,0x0003,0...}函数中的0x56c4,0x0003是怎样计算出来的?能不能把具体的计算过程告诉我?
jiahy 发表于 2017-6-9 22:49 | 显示全部楼层
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
 楼主| lizye 发表于 2017-6-9 22:52 | 显示全部楼层
#include <stdio.h>
#include <csl.h>
#include <csl_chip.h>
#include <csl_irq.h>
#include <csl_gpt.h>
#include <csl_uart.h>
#include \"Uart_Function.h\"
/* Reference start of interrupt vector table   */
/* This symbol is defined in file, vectors.s55 */
extern void VECSTART(void);
/* Function/ISR prototypes */
interrupt void Timer0Isr(void);
/* Create a TIMER_Handle object for use with TIMER_open */
GPT_Handle          hGpt;
Uint16 Counter;
Uint16 EventId0;                 // 定时器0所对应的事件ID号
/* Define and initialize the GPT module configuration structure */
/* Input fast peripheral clock is 100MHz                                                 */
/* Generate character interval interrupt    Note:1etu=1/9600秒         */
/* 10etu                0x19708                1.042ms        */
/* 12etu                0x1E870                1.250ms        */
/* 14etu                0x239D8                1.459ms        */
/* 20etu                0x32E10                2.084ms        */
/* 40etu                0x65C20                4.168ms        */
GPT_Config  MyGptConfig = {
0,                                 //Emulation management register
0,                                 //GPIO interrupt control register
0,                                        //GPIO enable register
0,                                        //GPIO direction register
0,                                       //GPIO data register
//0x39D8,                                             //Timer period register 1(主频为200MHz)
//0x0002,                                    //Timer period register 2
0x56C4,                                           //Timer period register 1(主频为300MHz)
0x0003,                                 //Timer period register 2
0,                                //Timer period register 3
0,
GPT_GPTCTL1_RMK(                        //Timer control register 1
  GPT_GPTCTL1_TIEN_NOT_GATED,
  GPT_GPTCTL1_CLKSRC_VBUS,
  GPT_GPTCTL1_ENAMODE_CONTINUOUS,
  GPT_GPTCTL1_PWID_INACTIVE_1CYCLE,
  GPT_GPTCTL1_CP_CLOCK_MODE,
  GPT_GPTCTL1_INVIN_DONT_INVERT_OUTPUT,
  GPT_GPTCTL1_INVOUT_DONT_INVERT_OUTPUT
GPT_GPTCTL2_RMK(                        //Timer control register 2
  GPT_GPTCTL2_TIEN_NOT_GATED,
  GPT_GPTCTL2_CLKSRC_VBUS,
  GPT_GPTCTL2_ENAMODE_CONTINUOUS,
  GPT_GPTCTL2_PWID_INACTIVE_1CYCLE,
  GPT_GPTCTL2_CP_CLOCK_MODE,
  GPT_GPTCTL2_INVIN_DONT_INVERT_OUTPUT,
  GPT_GPTCTL2_INVOUT_DONT_INVERT_OUTPUT
GPT_GPTGCTL1_RMK(                        //Global timer control register
  GPT_GPTGCTL1_PSC34_DEFAULT,
  GPT_GPTGCTL1_TIMMODE_DEFAULT,
  GPT_GPTGCTL1_TIM34RS_IN_RESET,
  GPT_GPTGCTL1_TIM12RS_IN_RESET
jiaxw 发表于 2017-6-9 22:54 | 显示全部楼层
那两参数是干啥的?我也不明白的啊。。
spark周 发表于 2017-6-9 22:56 | 显示全部楼层
后面说了定时周期寄存器. 应该是设置定时器的周期吧
 楼主| lizye 发表于 2017-6-9 22:59 | 显示全部楼层
嗯,我再好好缕一缕吧,有了好消息及时通知大家,结贴喽
