步进电机驱动问题
1762|0
 楼主| zhzy724 发表于 2010-5-11 18:11 | 显示全部楼层 |阅读模式
#include <reg52.h>
#define uint unsigned int
#define uchar unsigned char
uchar code FFW[]=   //正转
  0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09
uchar code REV[]= //反转
  0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01
sbit K1 = P3^0;
sbit K2 = P3^1;
sbit K3 = P3^2;
void DelayMS(uint ms)  //延时
  uchar i;
while(ms--)
   for(i=0;i<120;i++);
void SETP_MOTOR_FFW(uchar n)   //正转
  uchar i,j;
for(i=0;i<1*n;i++)
   for(j=0;j<8;j++)
    if(K3 == 0) break;
   P1 = FFW[j];
   DelayMS(25);
void SETP_MOTOR_REV(uchar n)  //反转
  uchar i,j;
for(i=0;i<1*n;i++)
   for(j=0;j<8;j++)
    if(K3 == 0) break;
   P1 = REV[j];
   DelayMS(25);
void main()
  uchar N = 1;
while(1)
   if(K1 == 0)
  {  while(K1==0);
    P0 = 0xfe; //正转LED指示
   SETP_MOTOR_FFW(N);
   if(K3 == 0) break;
  else if(K2 == 0)
  { while(K2==0);
    P0 = 0xfd; //反转LED指示
   SETP_MOTOR_REV(N);
   if(K3 == 0) break;
  else
    P0 = 0xfb;   //停LED指示
   P1 = 0x03;
当按下K1(K2)时怎么每次都正转72°(反转72°)?
怎么让它转18°?
