s51单片机串口收发的问题
7729|36
 楼主| hawk20022002 发表于 2010-5-31 20:44 | 显示全部楼层
我把void init_serialcom( void ) //串口通信初始设定
{TI=0;
中断里面也要有清TI的语句吗?
zjswuyunbo 发表于 2010-5-31 20:59 | 显示全部楼层
靠,自己思考下!
zjswuyunbo 发表于 2010-5-31 21:01 | 显示全部楼层
中断里不要用while(ti).随便看下别人的程序,参考下看看
eshowjow 发表于 2010-5-31 22:10 | 显示全部楼层
串口通讯的例子网上很多呢,有这时间讨论,早都抄到一个现成的了,
sxhhhjicbb 发表于 2010-5-31 23:19 | 显示全部楼层
可能的二种原因:一,你MCU的波特率和PC的偏差,这是异步采样的。二:你PC端调试软件加了UART结束位检测等功能。
ddxx 发表于 2010-6-1 08:10 | 显示全部楼层
给个例子你自己看看。
void sys_Init ( void )
          SCON = 0x50;                              /* mode 1:8bit UART;enable receiver                        */
        PCON |= 0x80;                                                /* SMOD = 1; BR = Timer1 OV                                        */
          TMOD |= 0x20;                              /* timer 1 mode 2: 8-Bit reload                                */
        TMOD &= 0x2f;                                                /* timer0 used by OS in Mode 0                                */
//         TH1   = 0xfd;                              /* F = 11.0592MHz; TH1 = 0xfd; BR =9600                */
        TH1   = 0xf3;                                                /* F = 24MHz; TH1 =0xf3; BR = 9600                        */
        IP = 0x1f;
          TR1 = 1;                                 /* timer 1 run        */
          ES = 1;                                 /* enable serial port interrupt                                */
        IT0 = 1;
        IE0 = 0;                                                        /* Clear flag        */
        IT1 = 1;
        IE1 = 0;                                                        /* Clear flag        */
        EX1 = 1;
        EX0 = 1;
//        T2MOD = 0x00;
        RCLK = 0;
        TCLK = 0;
        EXEN2 = 0;
        C_T2 = 0;
        CP_RL2 = 0;
        TF2 = 0;
        EXF2 = 0;
        RCAP2L = 0x00;
        RCAP2H = 0xC8;
        TL2 = RCAP2L;
        TH2 = RCAP2H;
        ET2 = 1;                                                        /* Enable Timer2 in Mode 1                                        */
        WDTD = 0xe0;
        WDTC = 0x0f;
        TR2 = 1;
        return;
void sp_tx_sem_take ( void )
sp_tx_sem0:
        EA  = 0;
        if ( sp_tx_sem == SEM_FULL )
                EA = 1;
                os_wait ( K_TMO, 1, 0 );
                goto sp_tx_sem0;
           sp_tx_sem = SEM_FULL;
        EA = 1;
        return;
void sp_tx_sem_give ( void )
        EA = 0;
        sp_tx_sem = SEM_EMPTY;
        EA = 1;
        return;        // OK
void sp_tx_start ( void )
        SBUF = SP_STX;
        return;
void sp_rx_sem_give ( void )
        EA = 0;
        sp_rx_sem = SEM_EMPTY;
        sp_rx_len = 0;
        EA = 1;
        return;        // OK
void serial_int ( void ) interrupt 4 using 2
        static unsigned char rx_cnt = 0;                /* State: idle, initial state                                         */
        static unsigned char tx_cnt = 0;
        if ( TI )
                        switch ( tx_cnt )
                        case 0x00:
                                tx_cnt ++;
                                SBUF = SP_ADDR_DVR;
                                break;
                        case 0x01:
                                tx_cnt ++;
                                SBUF = sp_tx_addr;
                                break;
                        case 0x02:
                                tx_cnt ++;
                                SBUF = sp_tx_cmd;
                                break;
                        case 0x03:
                                if ( sp_tx_len > 0 )
                                        sp_tx_len --;
                                        SBUF = sp_tx_buffer [ sp_tx_len ];
                                if ( sp_tx_len == 0 )
                                tx_cnt ++;
                                break;
                        case 0x04:
                                tx_cnt ++;
                                SBUF = SP_ETX;
                                break;
                        default:
                                tx_cnt = 0x00;
                                sp_tx_len = 0x00;
                                sp_tx_sem_give ();                                /* Transmission Complete, Release Semaphore                */
                                break;
                        TI = 0;        /* Clear Interrupt Flag                                                 */
           if ( RI )        /* Receive interrupt, clear flag RI, handled        */
                if ( sp_rx_sem == SEM_EMPTY )
                        switch ( rx_cnt )
                                 case 0x00 :
                                        if ( SBUF == SP_ADDR_KB )
                                                rx_cnt = 0x01;
                                        else
                                                rx_cnt = 0x00;
                                        break;
                                 case 0x01 :
                                        if ( SBUF == SP_ADDR_DVR )
                                                rx_cnt = 0x02;
                                          else
                                                rx_cnt = 0x00;
                                        break;
                                 case 0x02 :
                                        if ( SBUF == SP_STX )
                                                rx_cnt = 0x00;
                                                   break;
                                        sp_rx_cmd = SBUF;
                                        rx_cnt = 0x03;
                                        break;
                                 case 0x03 :
                                                rx_cnt = 0x00;
                                                sp_rx_len = 0x00;
                                                   break;
                                        if ( SBUF == SP_ETX )
                                                rx_cnt = 0x00;
                                                sp_rx_sem = SEM_FULL;
                                                isr_send_signal ( SP_RX );
                                        else
                                                sp_rx_buffer [ sp_rx_len ] = SBUF;
                                                sp_rx_len ++;
                                        break;
                                default :                                                        /* Machine state return idle state                                */
                                        rx_cnt = 0x00;
                                        sp_rx_len = 0x00;
                                         break;
                RI = 0;        /* Clear Interrupt Flag                                                        */
        return;
冷漠 发表于 2010-6-1 08:48 | 显示全部楼层
我用S51 单片机做的程序片段如下:用的是22。1184M晶振
    SCON = 0x50 ;   //UART为模式1,8位数据,允许接收
    TMOD |= 0x20 ; //定时器1为模式2,8位自动重装
    PCON |= 0x80 ; //SMOD=1;
//    TH1 = 0xFA ;   //Baud:19200 fosc="11".0592MHz
TH1=0XF4  ;      //9600    22.1184m      // ? ??
   IE |= 0x90 ;   //Enable Serial Interrupt
    TR1 = 1 ;       // timer 1 run
      TI=1;
9600/22.1184,应该TH1=0xFD!
TH1=0XFD  ;      //9600    22.1184m
 楼主| hawk20022002 发表于 2010-6-1 09:07 | 显示全部楼层
LS的是不是算错了。
冷漠 发表于 2010-6-1 09:28 | 显示全部楼层
对不起:又算了一下,下面0xF4是对的。
TH1=0XF4  ;      //9600    22.1184m    // 正确
一棵小草 发表于 2010-6-1 13:11 | 显示全部楼层
{TI=0;
中断里面也要有清TI的语句吗?
就按照这个改,中断中不用清零了,再试试。
因为我认为,你的中断让TI =0;
而你的send----当中,while(TI == 0);TI =0;因为中断中已经清零了,那么这里就可能死循环。
 楼主| hawk20022002 发表于 2010-6-1 13:15 | 显示全部楼层
现在改了之后是收到什么数据发什么数据,但是偶尔会出现发送一帧数据给单片机,比如有77个,但是调试助手收到的77个数据是2帧,数据都没错就是按2帧发送回来的。
 楼主| hawk20022002 发表于 2010-6-1 15:44 | 显示全部楼层
搞定了。。。谢谢大家
zj198828 发表于 2010-6-1 16:44 | 显示全部楼层
SCON  = 0x50;                        /* SCON: 模式 1, 8-bit UART, 使能接收         */
    TMOD |= 0x20;               /* TMOD: timer 1, mode 2, 8-bit reload        */
    TH1   = 0xFD;               /* TH1:  reload value for 9600 baud @ 11.0592MHz   */
    TR1   = 1;                  /* TR1:  timer 1 run                          */
    EA    = 1;                  /*打开总中断*/
    ES    = 1;                  /*打开串口中断*/
while (1)                       /*主循环不做任何动作*/
void UART_SER (void) interrupt 4 //串行中断服务程序
    unsigned char Temp;          //定义临时变量
   if(RI)                        //判断是接收中断产生
          RI=0;                      //标志位清零
          Temp=SBUF;                 //读入缓冲区的值
          P1=Temp;                   //把值输出到P1口,用于观察
      SBUF=Temp;                 //把接收到的值再发回电脑端
   if(TI)                        //如果是发送标志位,清零
     TI=0;
zj198828 发表于 2010-6-1 16:45 | 显示全部楼层
    EA    = 1;                  /*打开总中断*/
    ES    = 1;                  /*打开串口中断*/
   if(RI)                        //判断是接收中断产生
          RI=0;                      //标志位清零
     TI=0;
hanfei08131106 发表于 2010-6-1 22:50 | 显示全部楼层
同意18楼
lhbdyx1 发表于 2010-9-9 16:02 | 显示全部楼层
跟着学
