使用cvi gpib.h的控制软件,是不是只能用NI的GPI...
3368|2
 楼主| bit6019 发表于 2010-5-31 21:16 | 显示全部楼层 |阅读模式
示例代码:
          N4010A_BT = ibdev (0, N4010A_addr, NO_SAD, T10s, 1, 0);
  strcpy(write_buffer_NA,"*IDN?");
  n4010A_status = ibwrt (N4010A_BT, write_buffer_NA,strlen(write_buffer_NA));
  memset(read_buffer_NA, 0 , sizeof(read_buffer_NA));
  n4010A_status = ibrd (N4010A_BT,read_buffer_NA , 100);
使用cvi gpib.h里面的函数(ibdev/ibwrt/ibrd)来访问GPIB卡,是不是只能使用NI的gpib卡?
我使用agilent的GPIB卡,就是不行!同时装了NI488.2也不行。ibdev返回值是-1。
MTK ATE控制N4010和heithley 2303都是用的这些gpib.h的函数做的控制程序,使用agilent GPIB都不行。
麻烦给个提示,谢过
huzixian 发表于 2010-5-31 21:18 | 显示全部楼层
下面是Agilent的SICL的一个例子,差别很大,对吧?
/* gpibdev.c
This example program sends a scan list to a
switch and, while looping, closes channels and
takes measurements. */
#include
#include
main()
INST dvm;
Using SICL with GPIB 4
Agilent SICL User’s Guide 91
INST sw;
double res;
int i;
/* Log message and terminate on error */
ionerror (I_ERROR_EXIT);
/* Open the multimeter and switch sessions*/
dvm = iopen (“gpib0,9,3”);
sw = iopen (“gpib0,9,14”);
itimeout (dvm, 10000);
itimeout (sw, 10000);
/*Set up trigger*/
iprintf (sw, “TRIG:SOUR BUS\\n”);
/*Set up scan list*/
iprintf (sw,”SCAN (@100:103)\\n”);
iprintf (sw,”INIT\\n”);
for (i=1;i<=4;i++)
/* Take a measurement */
iprintf (dvm,”MEAS:VOLT:DC?\\n”);
/* Read the results */
iscanf (dvm,”%lf”,&res);
/* Print the results */
printf (“Result is %lf\\n”,res);
/* Trigger to close channel */
iprintf (sw, “TRIG\\n”);
/* Close the multimeter and switch sessions */
iclose (dvm);
iclose (sw);
return 0;
 楼主| bit6019 发表于 2010-5-31 21:24 | 显示全部楼层
上述代码中的函数,应该就是Agilent的GPIB函数了。倒是第一次见,谢谢支持!
