asleep 为什么不会显示? 在MPLAB SIM里
1796|0
 楼主| crazybee 发表于 2010-6-2 13:38 | 显示全部楼层 |阅读模式
When executing a Sleep instruction, MPLAB SIM will appear "asleep" until a wake-up from sleep condition occurs. For example, if the Watchdog Timer has been enabled, it will wake the processor up from sleep when it times out (depending upon the pre/postscaler setting).
上面是MPLAB IDE 有关SLEEP SIM说明,为什么我在软件DEBUG的时候,执行SLEEP指令,MPLAB IDE却没有显示“ASLEEP”呢?哪位知道?
个人签名:MSN: ihuangwh@foxmail.com
149
