430编译不通
2218|1
 楼主| lh0602 发表于 2010-6-4 09:58 | 显示全部楼层 |阅读模式
Building configuration: f2 - Release
flash.c
icc430.exe -I C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\INC\ -I C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\INC\DLIB\ -o E:\f2a100128\Release\Obj\ -z9 -e --double=64 -D_DLIB_CONFIG_FILE=C:\
Program Files\IAR Systems\Embedded Workbench 4.0\430\LIB\DLIB\dl430df.h E:\f2a100128\flash.c
   IAR MSP430 C/C++ Compiler V3.10A/W32
   Copyright 1996-2004 IAR Systems. All rights reserved.
Fatal Error[Pe005]: could not open source file "(0x0001):\Program Files\IAR Systems\Embedded Workbench 4.0\430\LIB\DLIB\dl430df.h"
Errors: 1
Warnings: none
uart.c
Program Files\IAR Systems\Embedded Workbench 4.0\430\LIB\DLIB\dl430df.h E:\f2a100128\uart.c
Errors: 1
Warnings: none
Total number of errors: 2
Total number of warnings: 0
我的程序以前是好的,设备已经在卖了,今天用户提出新要求,想修改一下,发现编译通不过,请指教
ayb_ice 发表于 2010-6-4 10:04 | 显示全部楼层
这是没有相关文件
