网上下了好几个代码,都大同小议,使用起来很不稳定,香水帮忙看下哪里的问题。
我用的I0有所变化,PC9-----WP
PC10----SDA
PC11----SCL
修改后程序如下:
#include <stm32f10x_lib.h>
bool I2C_FRAM_BufferWrite(u8* pBuffer, u16 WriteAddr, u16 NumByteToWrite);
bool I2C_FRAM_BufferRead(u8* pBuffer, u16 ReadAddr, u16 NumByteToRead);
#define I2C1_SLAVE_ADDRESS7 0xA0
#define I2C_PageSize 256
#define SCL_H GPIOC->BSRR = GPIO_Pin_11
#define SCL_L GPIOC->BRR = GPIO_Pin_11
#define SDA_H GPIOC->BSRR = GPIO_Pin_10
#define SDA_L GPIOC->BRR = GPIO_Pin_10
#define SCL_read GPIOC->IDR & GPIO_Pin_11
#define SDA_read GPIOC->IDR & GPIO_Pin_10
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
vu8 FRAM_ADDRESS;
/* Private function prototypes -----------------------------------------------*/
void I2C_delay(void)
u8 i=100; //这里可以优化速度 ,经测试最低到5还能写入
while(i)
i--;
bool I2C_Start(void)
SDA_H;
SCL_H;
I2C_delay();
if(!SDA_read)return FALSE; //SDA线为低电平则总线忙,退出
SDA_L;
I2C_delay();
if(SDA_read) return FALSE; //SDA线为高电平则总线出错,退出
SDA_L;
I2C_delay();
return TRUE;
void I2C_Stop(void)
SCL_L;
I2C_delay();
SDA_L;
I2C_delay();
SCL_H;
I2C_delay();
SDA_H;
I2C_delay();
void I2C_Ack(void)
SCL_L;
I2C_delay();
SDA_L;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
I2C_delay();
void I2C_NoAck(void)
SCL_L;
I2C_delay();
SDA_H;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
I2C_delay();
bool I2C_WaitAck(void) //返回为:=1有ACK,=0无ACK
SCL_L;
I2C_delay();
SDA_H;
I2C_delay();
SCL_H;
I2C_delay();
if(SDA_read)
SCL_L;
return FALSE;
SCL_L;
return TRUE;
void I2C_SendByte(u8 SendByte) //数据从高位到低位//
u8 i=8;
while(i--)
SCL_L;
I2C_delay();
if(SendByte&0x80)
SDA_H;
else
SDA_L;
SendByte<<=1;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
u8 I2C_ReceiveByte(void) //数据从高位到低位//
u8 i=8;
u8 ReceiveByte=0;
SDA_H;
while(i--)
ReceiveByte<<=1;
SCL_L;
I2C_delay();
SCL_H;
I2C_delay();
if(SDA_read)
ReceiveByte|=0x01;
SCL_L;
return ReceiveByte;
bool WriteFM24C04(u16 WriteAddr, u16 NumByteToWrite, u8 * pBuffer)
u8 Addr = 0, count = 0;
GPIOC->BRR = GPIO_Pin_9;//11
Addr = WriteAddr / I2C_PageSize;
count = WriteAddr % I2C_PageSize;
Addr = Addr << 1;
Addr = Addr & 0x0F;
FRAM_ADDRESS = I2C1_SLAVE_ADDRESS7 | Addr;
if (!I2C_Start()) return FALSE;
I2C_SendByte(FRAM_ADDRESS);//设置器件地址+段地址
if (!I2C_WaitAck())
I2C_Stop();
return FALSE;
I2C_SendByte(count); //设置段内地址
I2C_WaitAck();
while(NumByteToWrite--)
I2C_SendByte(* pBuffer);
I2C_WaitAck();
pBuffer++;
I2C_Stop();
//注意:因为这里要等待EEPROM写完,可以采用查询或延时方式(10ms)
//Systick_Delay_1ms(10);
return TRUE;
//读出1串数据
bool ReadFM24C04(u16 WriteAddr,u16 NumByteToRead, u8 * pBuffer)
//bool I2C_FRAM_BufferRead(u8* pBuffer, u16 WriteAddr, u16 NumByteToRead)
Addr = Addr << 1;
Addr = Addr & 0x0F;
if (!I2C_WaitAck())
I2C_Stop();
return FALSE;
I2C_SendByte(count); //设置低起始地址
I2C_WaitAck();
I2C_Start();
I2C_SendByte(FRAM_ADDRESS | 0x01);
I2C_WaitAck();
while(NumByteToRead)
*pBuffer = I2C_ReceiveByte();
if(NumByteToRead == 1)I2C_NoAck();
else I2C_Ack();
pBuffer++;
NumByteToRead--;
I2C_Stop();
return TRUE;
