linux报错,希望各位网友可以帮忙分析下!
5927|0
 楼主| lomeisi_99 发表于 2010-6-10 13:31 | 显示全部楼层 |阅读模式
错误信息是不确定的,主要为以下几种,
第一种
Internal error: Oops - undefined instruction: 0 [#1]
Modules linked in: usb_storage mousedev usbhid atp8624 hi3520_pciv_fmwm(P) hi3520_ao(P) hi3520_ai(P) hi3520_aenc(P) hi3520_adec(P) hi3520_md(P) hi3520_vpp(P) hi3520_group(P) hi3520_venc(P) hi3520_vdec(P) hi3520_simd(P) hi3520_viu(P) hi3520_vou(P) hi3520_vd(P) hi3520_dsu(P) hi3520_sys(P) hi3520_base(P) tde(P) hifb(P) ak_4633 it_6610 r8025 miscgpio higpio tw2864 gpioi2c1 gpioi2c mcc_usrdev ipcmcom fb mmz af_packet nls_iso8859_2 nls_ascii sd_mod msdos vfat fat nfs lockd nfs_acl sunrpc ext3 jbd h2gether libphy
CPU: 0
Tainted: P
(2.6.24-rt1-hi3520v100 #1)
PC is at 0xc99a1dac
LR is at HI_LOG+0x20/0x1e0 [hi3520_base]
pc : [<c99a1dac>]
lr : [<bf126574>]
psr: 60000113
sp : c99a1d20
ip : 00000000
fp : 00000000
r10: c00a4690
r9 : c9802040
r8 : c26a2000
r7 : 00001000
r6 : 00000000
r5 : 000815dc
r4 : c0340440
r3 : bf12c0dc
r2 : 00000003
r1 : 00000000
r0 : 00000000
Flags: nZCv
IRQs on
FIQs on
Mode SVC_32
ISA ARM
Segment user
Control: 00c5387f
Table: ebde8008
DAC: 00000015
Process ?毶 (pid: 0, stack limit = 0xc99a0258)
第二种:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 817 [#1]
CPU: 0
Tainted: P
PC is at cache_alloc_refill+0x1e0/0x5b8
LR is at 0xc11cc740
pc : [<c007ee3c>]
lr : [<c11cc740>]
psr: 60000093
sp : c8d49dd8
ip : c9c0a460
fp : c8d49e04
r10: c9c08bc0
r9 : c9c0a468
r8 : c9c0a460
r7 : c11cc03c
r6 : c9c2e000
r5 : 0000002f
r4 : c11cc020
r3 : 00000000
r2 : 00000028
r1 : 00200200
r0 : c2ce2020
Flags: nZCv
IRQs off
FIQs on
Mode SVC_32
ISA ARM
Segment kernel
Control: 00c5387f
Table: ebdd0008
DAC: 00000017
Process kjournald (pid: 687, stack limit = 0xc8d48258)
Stack: (0xc8d49dd8 to 0xc8d4a000)
9dc0:
00011200 00011210
9de0: 40000013 00011200 c9c08bc0 00000010 00000000 00000001 c8d49e24 c8d49e08
9e00: c007ec3c c007ec68 00011210 c9c32f60 00011200 c9c32f80 c8d49e34 c8d49e28
9e20: c0063228 c007ebe0 c8d49e6c c8d49e38 c00630d8 c0063218 0036200f c5a7ba40
9e40: 00000001 c5a7ba40 00000000 00000001 c8d06000 000000ee c9c32f80 00000010
9e60: c8d49e98 c8d49e70 c00a90ac c00630b4 00000000 000000d4 c8d06000 000000ee
程序运行的时间长短不定,同一批板子,有的运行的时间长,有的运行的时间段,但都会出错,
读写内存测试是好的,我是做硬件的,对linux也不懂,希望有人能指点一二,可能会是哪方面的问题,
我好去做相应的测试,头痛死了,先谢谢各位!
