紧急求助:TIM4的通道1通道2无法输出PWM波形
3010|1
 楼主| 路过打酱油 发表于 2010-6-13 22:18 | 显示全部楼层 |阅读模式
用TIM4输出4路通道的PWM波形,发现只有通道3和通道4出现PWM波形,通道1和通道2只出现高电平。CPU用的是RBT6。板子上焊接没有问题
下面是PWM的配置程序(我把其他无关程序都屏蔽了)
请高手帮我看看,很急啊 谢谢
void PWM_Configuration(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  GPIO_InitStructure.GPIO_Pin= GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(PORT_DRIVE, &GPIO_InitStructure);
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = PERIOD;
  TIM_TimeBaseStructure.TIM_Prescaler = 71;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = PERIOD/2;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC1Init(TIM4, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);
  TIM_OC2Init(TIM4, &TIM_OCInitStructure);
  TIM_OC2PreloadConfig(TIM4, TIM_OCPreload_Enable);
  TIM_OC3Init(TIM4, &TIM_OCInitStructure);
  TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable);
  TIM_OC4Init(TIM4, &TIM_OCInitStructure);
  TIM_OC4PreloadConfig(TIM4, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM4, ENABLE);
  /* TIM4 enable counter */
  TIM_Cmd(TIM4, ENABLE);
 楼主| 路过打酱油 发表于 2010-6-14 10:38 | 显示全部楼层
:L解决了
原来我把APB1的时钟都开了 就不行
只开TIM4的时钟就可以了
