[Actel FPGA]
FPGA程序下载问题
3348|4
米其林r|  楼主 | 2010-6-16 23:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教问题:我的FPGA在进行最后一项PROGRAM的时候总是出现如下错误。
programmer '05015' : Scan Chain...
Error: programmer '05015' : Signal Integrity Failure
       Integrity Check Pattern Not Found.
       Integrity Check Pattern :
       550FAAF000FF0000FFFF
       IrScan Error.
       TDO stuck at 0
       Chain Analysis Failed.
Error: programmer '05015' : Data Bit length : 8272
Error: programmer '05015' : Compare Data  : 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Error: programmer '05015' : Scan Chain FAILED.
Error: Failed to run Action.
请大虾帮忙看一下,我该怎么解决。
还有一问就是:怎样判断芯片是否被加密?
谢谢!
无语凝咽| | 2010-6-17 23:03 | 只看该作者
请将打印机端口打开,在开始->控制面板->管理工具->服务中,找到Print Spooler,然后启动~
米其林r|  楼主 | 2010-6-17 23:15 | 只看该作者
我看过了,打印端口是打开的,可还是不行啊,换了好几片芯片也是这样的问题。郁闷啊!
yelinggtx| | 2010-6-18 16:58 | 只看该作者
检查下载器与JTAG口连接是否正常(应该是这问题),确认后检查并口驱动是否安装,如何安装,请联系当地ZLG FAE
3B1105| | 2010-8-8 14:14 | 只看该作者
看不懂啊
