求助DS12C887+实时时钟
1951|0
 楼主| lin34337151 发表于 2010-6-19 11:38 | 显示全部楼层 |阅读模式
#include<reg52.h>
#include<intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit rs=P2^0;
sbit lcden=P2^2;
sbit rw=P2^1;
sbit dsas=P2^5;
sbit dsrw=P2^6;
sbit dsds=P2^7;
sbit dscs=P2^4;
char shi,fen,miao;
uchar code table[]="   2010-06-14   ";
uchar code table1[]="      :  :      ";
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void write_com(uchar com)   //1602A写命令
    rw=0;
rs=0;
lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)    //1602A写数据
    rw=0;
rs=1;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_sfm(uchar add,uchar date)   //写十分秒,把两位数分离成两个一位数
uchar shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi); //0X30是ASC码转换
write_date(0x30+ge);//ASC码转换
void write_ds(uchar add,uchar date)
dsas=1;
dsds=1;
dsrw=1;
    dscs=0;
P1=add;
    _nop_();
    _nop_();
dsas=0;
    _nop_();
    _nop_();
dsrw=0;
P1=date;
    _nop_();
    _nop_();
dsrw=1;
dsas=1;
dscs=1;
//   delay(1);
uchar read_ds(uchar add)
  uchar ds_date;
dsas=1;
dsds=1;
dsrw=1;
dscs=0;
P1=add;
    _nop_();
    _nop_();
dsas=0;
    _nop_();
    _nop_();
dsds=0;
    _nop_();
    _nop_();
P1=0xff;
ds_date=P1;
    _nop_();
    _nop_();
dsds=1;
    _nop_();
dsas=1;
dscs=1;
return ds_date;
   // delay(1);
void start()
   write_ds(0x0a,0x20); //开启晶振,让时钟运行
void set_time()
    write_ds(0x0b,0x86); //SET 置1允许写,不能读
write_ds(4,0x0a);    //设置小时为10点
write_ds(2,0x08);   //设置分为08分
write_ds(0x0b,0x06); //SET置0可以读,不能写
void init()
uchar num;
lcden=0;
    delay(1);
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<15;num++)
   write_date(table[num]);
   delay(5);
write_com(0x80+0x40);
for(num=0;num<12;num++)
   write_date(table1[num]);
   delay(5);
void busy_ds()
    uchar temp;
    temp=read_ds(0x0a);
   // temp=temp&0x80;
    while((temp&0x80)==0x80);
void gettime()
    busy_ds();
miao=read_ds(0);
    busy_ds();
fen=read_ds(2);
    busy_ds();
shi=read_ds(4);
void main()
    start();
    set_time();
    init();
while(1)
            gettime();
   write_sfm(10,miao);
      write_sfm(7,fen);
         write_sfm(4,shi);
连接方法as接P2^5;rw接P2^6;ds接P2^7;cs接P2^4;A0-A7接P1口,MOT接地,
reset接VCC。我怎么也读取不到时钟信息,请高手指点一下
