DSP交通灯的设计
4866|4
 楼主| 雨在雪中飘 发表于 2010-6-19 12:30 | 显示全部楼层 |阅读模式
以下是交通灯的程序
解释一下,哪句话是控制交通灯亮灭时间的
具体应该怎样改动可以施行
#include "scancode.h"
#define SPSA0 *(unsigned int *)0x38
#define SPSD0 *(unsigned int *)0x39
#define REGISTERCLKMD (*(unsigned int *)0x58)
#define TIM  *(int *)0x24
#define PRD     *(int *)0x25
#define TCR  *(int *)0x26
#define IMR  *(int *)0x0
#define IFR  *(int *)0x1
#define PMST *(int *)0x1d
#define nStatusNSGreenEWRed 160
#define nStatusNSFlashEWRed 184
#define nStatusNSYellowEWRed 200
#define nStatusNSRedEWYellow 216
#define nStatusNSRedEWGreen 376
#define nStatusNSRedEWFlash 400
#define nStatusNSRedEWYellow1 416
#define nStatusNSYellowEWRed1 432
#define nTotalTime 448
#define nStatusHold 160
#define statusNSGreenEWRed 0
#define statusNSFlashEWRed 1
#define statusNSYellowEWRed 2
#define statusNSRedEWYellow 3
#define statusNSRedEWGreen 4
#define statusNSRedEWFlash 5
#define statusHold 6
#define LCDDELAY 1
#define LCDCMDTURNON 0x3f
#define LCDCMDTURNOFF 0x3e
#define LCDCMDSTARTLINE 0xc0
#define LCDCMDPAGE 0xb8
#define LCDCMDVERADDRESS 0x40
ioport unsigned int port3004;
//  CTR扩展寄存器定义
ioport unsigned int port8000;
ioport unsigned int port8001;
ioport unsigned int port8002;
ioport unsigned int port8003;
ioport unsigned int port8004;
ioport unsigned int port8005;
ioport unsigned int port8007;
#define CTRGR       port8000
#define CTRLCDCMDR  port8001
#define CTRKEY      port8001
#define CTRCLKEY    port8002
#define CTRLCDCR    port8002
#define CTRLCDLCR   port8003
#define CTRLCDRCR   port8004
#define CTRLA       port8005
#define CTRLR       port8007
void InitDSP();
void InitTimer();
void InitICETEKCTR();
void interrupt time(void);
void interrupt xint2(void); // XINT2中断服务程序
void SetLEDArray(int nNumber);  // 修改显示内容
void RefreshLEDArray();   // 刷新显示
void EndICETEKCTR();
void TurnOnLCD();
void LCDCLS();
void Delay(unsigned int nDelay);
unsigned int uWork,nTimeCount;
unsigned int uLightStatusEW,uLightStatusSN;
unsigned int bHold;
unsigned char ledbuf[8],ledx[8];
unsigned char led[40]=
0x7E,0x81,0x81,0x7E,0x00,0x02,0xFF,0x00,
0xE2,0x91,0x91,0x8E,0x42,0x89,0x89,0x76,
0x38,0x24,0x22,0xFF,0x4F,0x89,0x89,0x71,
0x7E,0x89,0x89,0x72,0x01,0xF1,0x09,0x07,
0x76,0x89,0x89,0x76,0x4E,0x91,0x91,0x7E
unsigned char ledkey[10][8]=
{0x00,0x00,0x7C,0x82,0x82,0x82,0x7C,0x00}, //0
{0x00,0x00,0x00,0x84,0xFE,0x80,0x00,0x00}, //1
{0x00,0x00,0x84,0xC2,0xA2,0x92,0x8C,0x00}, //2
{0x00,0x00,0x44,0x92,0x92,0x92,0x6C,0x00},
{0x00,0x00,0x30,0x28,0x24,0xFE,0x20,0x00},
{0x00,0x00,0x4E,0x92,0x92,0x92,0x62,0x00},
{0x00,0x00,0x7C,0x92,0x92,0x92,0x64,0x00},
{0x00,0x00,0x02,0xC2,0x32,0x0A,0x06,0x00},
{0x00,0x00,0x6C,0x92,0x92,0x92,0x6C,0x00},
{0x00,0x00,0x4C,0x92,0x92,0x92,0x7C,0x00}
main()
int nWork1,nWork2,nWork3,nWork4,tKey;
int nNowStatus,nOldStatus,nOldTimeCount,nSaveTimeCount,nSaveStatus;
unsigned int nScanCode;
nTimeCount=0; bHold=0;
uLightStatusEW=uLightStatusSN=0;
nNowStatus=0; nOldStatus=1; nOldTimeCount=0;
InitDSP();   // 初始化DSP,设置运行速度
InitICETEKCTR(); // 初始化显示/控制模块
InitTimer();  // 设置定时器中断
// 根据计时器计数切换状态
// 根据状态设置计数和交通灯状态
while ( 1 )
  if ( bHold && nNowStatus==statusHold )
   if ( nTimeCount>=nStatusHold )
    nNowStatus=nSaveStatus;
    nTimeCount=nSaveTimeCount;
    bHold=0;
  else if ( nTimeCount<nStatusNSGreenEWRed ) nNowStatus=statusNSGreenEWRed;
  else if ( nTimeCount<nStatusNSFlashEWRed ) nNowStatus=statusNSFlashEWRed;
  else if ( nTimeCount<nStatusNSYellowEWRed ) nNowStatus=statusNSYellowEWRed;
  else if ( nTimeCount<nStatusNSRedEWYellow ) nNowStatus=statusNSRedEWYellow;
  else if ( nTimeCount<nStatusNSRedEWGreen ) nNowStatus=statusNSRedEWGreen;
  else if ( nTimeCount<nStatusNSRedEWFlash ) nNowStatus=statusNSRedEWFlash;
  else if ( nTimeCount<nStatusNSRedEWYellow1 ) nNowStatus=statusNSRedEWYellow;
  else if ( nTimeCount<nStatusNSYellowEWRed1 ) nNowStatus=statusNSYellowEWRed;
  if ( nNowStatus==nOldStatus )
   switch ( nNowStatus )
    case statusNSFlashEWRed:
     nWork1=nTimeCount-nStatusNSGreenEWRed;
     nWork2=nStatusNSYellowEWRed-nStatusNSFlashEWRed;
     nWork3=nWork2/3;
     nWork4=nWork3/2;
     if ( nWork1>=0 && nWork2>0 && nWork3>0 && nWork4>0 )
      uLightStatusSN=( (nWork1%nWork3)<=nWork4 )?(0x49):(0x40);
     break;
    case statusNSRedEWFlash:
     nWork1=nTimeCount-nStatusNSRedEWGreen;
     nWork2=nStatusNSRedEWYellow1-nStatusNSRedEWFlash;
     nWork3=nWork2/3;
     nWork4=nWork3/2;
      uLightStatusEW=( (nWork1%nWork3)<=nWork4 )?(0x09):(0x00);
     break;
    case statusNSGreenEWRed:
     nWork1=nStatusNSGreenEWRed/20;
     if ( nWork1>0 )
      nWork2=20-nTimeCount/nWork1;
      if ( bHold )
       if ( nWork2>10 )
        nTimeCount=nWork1*10;
        nWork2=10;
      if ( nOldTimeCount!=nWork2 )
       nOldTimeCount=nWork2;
       SetLEDArray(nWork2);
     break;
    case statusNSRedEWGreen:
     nWork1=(nStatusNSRedEWGreen-nStatusNSRedEWYellow)/20;
     if ( nWork1>0 )
      nWork2=20-(nTimeCount-nStatusNSRedEWYellow)/nWork1;
      if ( bHold )
       if ( nWork2>10 )
        nTimeCount=nStatusNSRedEWYellow+nWork1*10;
        nWork2=10;
     break;
    case statusHold:
     nWork1=nStatusHold/20;
     if ( nWork1>0 )
     break;
  else
   if ( bHold )
    nSaveStatus=nNowStatus;
    nSaveTimeCount=nTimeCount;
    nNowStatus=statusHold;
    nTimeCount=0;
    if ( nSaveStatus==statusNSFlashEWRed || nSaveStatus==statusNSYellowEWRed )
     nSaveStatus=statusNSRedEWGreen;
     nSaveTimeCount=nStatusNSRedEWYellow;
    else if ( nSaveStatus==statusNSRedEWFlash || nSaveStatus==statusNSRedEWYellow )
     nSaveStatus=statusNSGreenEWRed;
     nSaveTimeCount=0;
   nOldStatus=nNowStatus;
     uLightStatusEW=0x24; uLightStatusSN=0x49;
     SetLEDArray(20);
     break;
     SetLEDArray(0);
     break;
    case statusNSYellowEWRed:
     uLightStatusEW=0x24; uLightStatusSN=0x52;
     SetLEDArray(20);
     break;
    case statusNSRedEWYellow:
     uLightStatusEW=0x12; uLightStatusSN=0x64;
     SetLEDArray(20);
     break;
     uLightStatusEW=0x09; uLightStatusSN=0x64;
     SetLEDArray(20);
     break;
     SetLEDArray(0);
     break;
    case statusHold:
     uLightStatusEW=0x24; uLightStatusSN=0x64;
     SetLEDArray(20);
     break;
  CTRLR=uLightStatusEW; CTRLR=uLightStatusSN; // 设置交通灯状态
  RefreshLEDArray(); // 刷新发光二极管显示
  nScanCode=port8001; // 读键盘扫描码
  nScanCode&=0x0ff;
  tKey=CTRCLKEY;
  if ( nScanCode==SCANCODE_9 ) break;
EndICETEKCTR();
exit(0);
// 定时器中断服务程序,进行时钟计数
nTimeCount++;
nTimeCount%=nTotalTime;
// 设置发光二极管显示内容
    int i,ShowNumber;
    ShowNumber=nNumber/2;
    if(ShowNumber>9)  ShowNumber=0;
CTRLCDCMDR=LCDCMDPAGE;  // 设置操作页=0
Delay(LCDDELAY);
CTRLCDCR=0;
Delay(LCDDELAY);
CTRLCDCMDR=LCDCMDVERADDRESS; // 起始列=0
Delay(LCDDELAY);
CTRLCDCR=0;
Delay(LCDDELAY);
for ( i=0;i<8;i++ )
  CTRLCDLCR=ledkey[ShowNumber][i];
  Delay(LCDDELAY);
  CTRLCDCR=0;
  Delay(LCDDELAY);
// 将缓存中点阵送发光二极管显示
int i;
for ( i=0;i<8;i++ )
  CTRGR=ledx[i];
  CTRLA=ledbuf[i];
// 初始化DSP,设置运行速度=8MHz
void InitDSP()
REGISTERCLKMD=0; // 复位PLL
REGISTERCLKMD=0x1007; // 速度设置=16MHz
// 设置定时器参数、允许中断
void InitTimer()
unsigned int k;
asm(" ssbx INTM"); // 关中断,进行关键设置时不许打扰
// 设置通用定时器
k=PMST;   // 设置PMST寄存器
PMST =k&0xff; // 中断向量表起始地址=80H
IMR = 0x0c;  // 使能TINT
TCR = 0x41f; // 预分频系数为16
TIM = 0;  // 时钟计数器清0
PRD = 0x0f423; // 周期寄存器为0ffH
TCR = 0x42f; // 复位、启动
IFR = 0x0c;  // 清中断标志位
port3004=0;   // 使能XINT2
asm(" rsbx INTM"); // 开中断
// 初始化ICETEK-CTR板上设备
int k;
CTRGR=0;  // 初始化ICETEK-CTR
CTRGR=0x80;
CTRGR=0;
CTRLR=0;  // 关闭东西方向的交通灯
CTRLR=0x40; // 关闭南北方向的交通灯
CTRLR=0x0c1; // 开启发光二极管显示阵列
CTRLR=0xc8;    //使能外部中断
for ( k=0;k<8;k++ )
  ledbuf[k]=0x0ff;  // 显示为空白
  ledx[k]=(k<<4); // 生成显示列控制字
k=CTRCLKEY; // 清除键盘缓冲区
TurnOnLCD();    // 打开显示
LCDCLS();    // 清除显示内存
CTRLCDCMDR=LCDCMDSTARTLINE;  // 设置显示起始行
CTRLCDCR=0;
void interrupt xint2(void) // XINT2中断服务程序
bHold=1;
void EndICETEKCTR()
int k;
CTRLR=0x0c0; // 关闭发光二极管显示阵列
void TurnOnLCD()
CTRLCDCMDR=LCDCMDTURNON;
Delay(LCDDELAY);
CTRLCDCR=0;
Delay(LCDDELAY);
Delay(LCDDELAY);
CTRLCDCR=0;
Delay(LCDDELAY);
void LCDCLS()
int i,j;
Delay(LCDDELAY);
CTRLCDCR=0;
Delay(LCDDELAY);
for ( i=0;i<8;i++ )
  CTRLCDCMDR=LCDCMDPAGE+i;
  Delay(LCDDELAY);
  CTRLCDCR=0;
  Delay(LCDDELAY);
  Delay(LCDDELAY);
  CTRLCDCR=0;
  Delay(LCDDELAY);
  for ( j=0;j<64;j++ )
   CTRLCDLCR=0;
   Delay(LCDDELAY);
   CTRLCDCR=0;
   Delay(LCDDELAY);
  Delay(LCDDELAY);
  CTRLCDCR=0;
  Delay(LCDDELAY);
  Delay(LCDDELAY);
  CTRLCDCR=0;
  Delay(LCDDELAY);
   CTRLCDRCR=0;
   Delay(LCDDELAY);
   CTRLCDCR=0;
   Delay(LCDDELAY);
int ii,jj,kk=0;
for ( ii=0;ii<nDelay;ii++ )
  for ( jj=0;jj<1024;jj++ )
   kk++;
xwj 发表于 2010-6-19 12:41 | 显示全部楼层
LZ在做毕业设计?
超级上海人 发表于 2010-6-23 07:12 | 显示全部楼层
用汇编语言对定时器8253、中断控制器8259A和并行接口8255A编程定时输出,令红绿黄LED交替点亮和熄灭模拟交通灯,并且用LED数码管倒计时显示时间。
sounysun 发表于 2013-3-6 16:59 | 显示全部楼层
谢谢楼主分享!
sounysun 发表于 2013-3-6 17:02 | 显示全部楼层
楼主可否帮帮我,我也做这个毕业设计呢
