哪有1206封装的大电流500mA磁珠?1210封装3.3uH/250mA电感呢?
7320|3
 楼主| 音乐乐乐 发表于 2007-1-28 16:51 | 显示全部楼层 |阅读模式
tyw 发表于 2007-1-28 17:03 | 显示全部楼层
去这里看
<font color=#FF0040>网址在这里→&nbsp;</font>&nbsp;&nbsp;&nbsp;<font color=#0040FF>http://www.torch.com.cn/product/index.htm</font><br />&nbsp;<table class=ubb cellspacing=0><TR><td class=ubb>大容量多层陶瓷电容器&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>标准型多层陶瓷电容器&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>中高耐压多层陶瓷电容器&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>高频用(高Q)多层陶瓷电容器&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>多层陶瓷电容排&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>超低失真多层陶瓷电容器(替代薄膜电容)&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>KEMET</td><td class=ubb>片状多层陶瓷电容器</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>片状高压电容器</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>开路式陶瓷电容器</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>有可靠性指标的多层瓷介片式电容器<br />MIL-PRF-55681</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>多层陶瓷电容排</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>TORCH&nbsp;</td><td class=ubb>片式多层瓷介电容器</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>片式高压电容器&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>军用“七专”多层瓷介片式电容器&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>军筛多层瓷介片式电容器&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>引线电容&nbsp;</td><td class=ubb>TORCH&nbsp;</td><td class=ubb>引线式多层瓷介电容器(立式)&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>镍电极多层瓷介电容器(可替代引线钽电容)&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>军用“七专”多层瓷介引线电容器&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>军筛多层瓷介引线电容器&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>TAIYO&nbsp;YUDEN&nbsp;</td><td class=ubb>轴向引线电容器(卧式)</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>钽电容&nbsp;</td><td class=ubb>KEMET&nbsp;</td><td class=ubb>T491系列 工业级片式钽电容</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>T492系列&nbsp;MIL-PRF-55365/8军用钽电容&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>T494系列&nbsp;工业级低ESR片式钽电容&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>T495系列&nbsp;工业级低ESR片式钽电容</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>T520&nbsp;KO聚合物钽电容&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>T530&nbsp;多电极KO聚合物钽电容&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>MIL-PRF-39003 有可靠性指标的管状轴向引线极<br />性固体钽电容器&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>MIL-PRF-39006 有可靠性指标的(钽壳)液态钽电<br />容器&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>贴片电阻&nbsp;</td><td class=ubb>TORCH&nbsp;</td><td class=ubb>高精度、低阻值、大功率、标准系列贴片电阻&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>电阻排&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>TAIYO&nbsp;YUDEN&nbsp;</td><td class=ubb>热敏电阻(小体积,手机适用)&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>压敏电阻(小体积,低压型,手机适用)&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>HDK&nbsp;</td><td class=ubb>超微型、低阻值、超高阻值、高压、可熔断、标准<br />系列贴片电阻、电阻排&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>贴片电感</td><td class=ubb>TAIYO&nbsp;YUDEN&nbsp;</td><td class=ubb>绕线型电感器LB系列&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>绕线型电感器LBH系列</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>多层片状电感器LK系列</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>多层片状电感器CK系列</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>多层片状电感器HK系列</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>薄型SMD电感器&nbsp;NR系列</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>大电流片状电感器&nbsp;N系列</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>引线电感</td><td class=ubb>TAIYO&nbsp;YUDEN</td><td class=ubb>轴向型引线电感&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>径向型引线电感&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>磁珠</td><td class=ubb>TAIYO&nbsp;YUDEN</td><td class=ubb>多层铁氧体磁珠&nbsp;BK系列&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>多层铁氧体磁珠&nbsp;BK系列&nbsp;P型(大电流)&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>多层铁氧体磁珠排&nbsp;BK系列&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>大电流铁氧体片式磁珠&nbsp;FB系列&nbsp;M型&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>晶体振荡器</td><td class=ubb>HDK</td><td class=ubb>温补晶体振荡器</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>其他组件&nbsp;</td><td class=ubb>TAIYO&nbsp;YUDEN&nbsp;</td><td class=ubb>压电扬声器&nbsp;MLS&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR><TR><td class=ubb>EMI降噪滤波器&nbsp;</td><td class=ubb><img src="http://pdf_b.gif">&nbsp;</td></TR></table>
 楼主| 音乐乐乐 发表于 2007-1-28 21:48 | 显示全部楼层
多谢,找到了taiyo yuden,
&nbsp;不过他们的产品电流都很大(与其他公司相比),可能价格也比较高?明天去问问,3.3uH&nbsp;3225的电感电流达1A以上,而其他公司的产品都在260mA,260mA比较适合点,呵呵。
Greenisbest 发表于 2024-3-27 16:27 | 显示全部楼层
&nbsp;不过他们的产品电流都很大(与其他公司相比),可能价格也比较高?明天去问问,3.3uH&nbsp;3225的电 ...
如果想要价格便宜一点的,同样参数的。可以找我。国产化替代你这个TAIYO 电感。17688764536
