一个智林LPC1114核心板的程序
2135|0
ddllxxrr|  楼主 | 2010-6-20 16:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
                                     [url=]\\\|///[/url]
+---------------------oOOo-(_)-oOOo-------------------------+
|                       Z111x Demo                                         |
|                 刘笑然 by Xiaoran Liu                                  |
|                        2010.3.26                                            |
|        智林测控技术研究所 ZERO Research Institute         |
|                      www.the0.net                                       |
|                                         Oooo                                  |
+-----------------------oooO--(   )-------------------------+
                                    \ (   (_/
                                     \_)
|  引入相关芯片的头文件                                    |
#include <LPC11xx.h>   /* LPC11xx Peripheral Registers */
#include "system_LPC11xx.h"
| HARDWARE DEFINE                                          |
#define LED       (1<<5)      /* LED D1 connect to PIO3_5 */
|  Delay  延时 Inserts a delay time.                       |
|  nCount: 延时时间 specifies the delay time length.       |
void Delay(unsigned nCount) {
  for(; nCount != 0; nCount--);
| MIAN ENTRY                                               |
int main() {
  SystemInit();
  /* Enable AHB clock to the GPIO domain. */
  LPC_SYSCON->SYSAHBCLKCTRL |= (1<<6);
  LPC_GPIO3->DIR |= LED;      // pin output
  for(;;) {
    LPC_GPIO3->DATA &= ~LED;  // reset pin : LED light
   Delay(2000000);
    LPC_GPIO3->DATA |=  LED;  // set pin: LED off
   Delay(2000000);
/*---------------------  END OF FILE  ----------------------*\
|                        COPYRIGHT                         |
|                      www.the0.net                        |
1.0 - GPIO_OUT.rar (73.96 KB)
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2400
