 这玩意目前就看到一家卖的,246USD,呵呵,国内还没找到卖的。
 原网址如下
 http://www.dhgate.com/4pcs-lot-anti-camera-super-sleuth-camera/p-ff8080811eb5c587011eb9f51e193939.html
 Spy Hidden Camera Lens Detector & SweeperIt uses an array of ultra bright LEDs that create a strong reflection from a camera’s lens that is easily detected. Unique to this device, users simply look through the view-window to identify hidden cameras lens in a room.
 Main features of the camera lens detector1. An array of ultra bright LEDs to detect camera lens
 2.
 Weight:38g
 3.
 Five model flicker frequencies of LEDs are available
 4.
 6 Ultra Bright Red LEDs
 5.
 Dimension: 62x48x9mm
 6.
 Power Source: Internal Li Ion Battery, 5 VDC Charging
 This camera lens detector dose not rely on detecting the RF signal from a wireless camera or the oscillator frequency radiated by a wired camera, it uses an array of ultra bright LEDs that create a strong reflection from a camera’s lens that is easily detected.
 Packing list Camera lens detector x1 Charger x1 USB Cable x1
 技术含量不高的,深圳有山寨货不?
