[ZLG-ARM] lpc2132的串口驱动(中断方式)
4225|11
 楼主| LPC300 发表于 2010-6-23 21:51 | 显示全部楼层 |阅读模式
#include "lpc213x.h"
#include "Includes.h"
#define BIT(x)  (1<<x)
#define SET_BIT(x, y)   (x|=(1<<y))
#define CLR_BIT(x, y)   (x&=~(1<<y))
#define GET_BIT(x, y)   (x&(1<<y))
volatile struct
    INT8U  rd_buf[32];
    INT8U  td_buf[2048];
    INT16U rd_max;
    INT16U td_max;
    INT16U rd_cnt;
    INT16U td_cnt;
} uart0;
OS_EVENT *uart0_rd_ok;
OS_EVENT *uart0_td_ok;
extern void UART0_Handler(void);
void UART0_Exception(void)
       unsigned char i, k;
       k = U0IIR&0x0F;
    switch(k)
        case 0x02:
            for (i=0; i<16; i++)
                if (uart0.td_cnt < uart0.td_max)
                    U0THR = uart0.td_buf[uart0.td_cnt];
                    uart0.td_cnt++;
                else
                    U0IER = U0IER & (~0x02);
                    OSSemPost(uart0_td_ok);
                    goto UART0_Exception_RET;
            break;
        case 0x04:
            for (i=0; i<8; i++)
                uart0.rd_buf[uart0.rd_cnt] = U0RBR;
                if (uart0.rd_buf[0] == 0xFD)
                    uart0.rd_cnt++;
                    if (uart0.rd_cnt == uart0.rd_max)
                        OSSemPost(uart0_rd_ok);
                    else if (uart0.rd_cnt > 31)
                        uart0.rd_cnt = 31;
            break;
        case 0x0C:
                uart0.rd_cnt++;
                    uart0.rd_cnt = 31;
            break;
        default:
            break;
UART0_Exception_RET:
      VICVectAddr = 0x00;
void UART0_init(void)
    INT16U i;
    for (i=0; i<32; i++)
        uart0.rd_buf[i] = 0x00;
    for (i=0; i<2048; i++)
        uart0.td_buf[i] = (unsigned char)i;
    uart0.rd_max = 8;
    uart0.td_max = 0;
    uart0.rd_cnt = 0;
    uart0.td_cnt = 0;
    SET_BIT(PINSEL0, 0);
    CLR_BIT(PINSEL0, 1);
    SET_BIT(PINSEL0, 2);
    CLR_BIT(PINSEL0, 3);
    U0LCR = 0x83;
       U0DLL = 0x06;
       U0DLM = 0x00;
       U0LCR = 0x03;
       U0FCR = 0x87;
       U0IER = 0x01;
       VICIntSelect = 0x00000000;
       VICVectCntl1 = 0x26;
       VICVectAddr1 = (unsigned long)UART0_Handler;
       VICIntEnable = (1<<6);
void UART0_putc(unsigned char c)
    U0THR = c;
    while ((U0LSR&0x40) == 0)
void UART0_puts(char *p)
    while(*p)
        UART0_putc(*p);
           p++;
void UART0_send(INT16U len)
    //unsigned short i;
    //for (i=0; i<len; i++)
    //    UART0_putc(uart0.td_buf[i]);
    uart0.td_cnt = 0;
    uart0.td_max = len;
    if (uart0.td_max > 0)
           uart0.td_cnt++;
           U0IER = U0IER | 0x02;                       /* 允许发送中断 */
void UART0_task(void *pdata)
    INT8U err;
    pdata = pdata;
    uart0_rd_ok = OSSemCreate(0);
    uart0_td_ok = OSSemCreate(0);
    UART0_init();
    do
        OSSemPend(uart0_rd_ok, 0, &err);
        UART0_send(1024);
        OSSemPend(uart0_td_ok, 0, &err);
        uart0.rd_cnt = 0;
    } while(1);
6019实验室 发表于 2010-6-23 21:52 | 显示全部楼层
谢谢啦中断看了几天都不明白,这下好了,虽然我的是2104
无语凝咽 发表于 2010-6-23 21:52 | 显示全部楼层
在多任务中,串口驱动,当一个设备想使用串口时,必须保证当时串口是空闲,如果不空闲,必须等待,直到空间,或者指定时间内串口设备未空闲,提示信息,
楼上的串口驱动采用结构,比较不错
但是要是用在多任何中,如果用多个任何使用此串口,估计会有问题
米其林r 发表于 2010-6-23 21:52 | 显示全部楼层
采用信号量太占用资源,不如用 Uart0Status=OSFlagCreate表示状态,另外,其实完全可以将串口的忙闲状态等信息一块封装在结构中,这样不断模块化,同时,一个状态只占用一个信息,
 楼主| LPC300 发表于 2010-6-23 21:53 | 显示全部楼层
呵呵,改了一下
volatile struct
    INT8U  rd_buf[32];
    INT8U  td_buf[2048];
    INT16U rd_max;
    INT16U td_max;
    INT16U rd_cnt;
    INT16U td_cnt;
    OS_EVENT *rd_ok;
    OS_EVENT *td_ok;
} uart0;
       unsigned char i, k;
       k = U0IIR&0x0F;
    switch(k)
        case 0x02:
                    uart0.td_cnt++;
                else
                    OSSemPost(uart0.td_ok);
            break;
        case 0x04:
            for (i=0; i<8; i++)
                    uart0.rd_cnt++;
                        OSSemPost(uart0.rd_ok);
                        uart0.rd_cnt = 31;
            break;
        case 0x0C:
                uart0.rd_cnt++;
                    uart0.rd_cnt = 31;
            break;
        default:
            break;
      VICVectAddr = 0x00;
    INT16U i;
    uart0.rd_max = 8;
    uart0.td_max = 0;
    uart0.rd_cnt = 0;
    uart0.td_cnt = 0;
    uart0.rd_ok = OSSemCreate(0);
    uart0.td_ok = OSSemCreate(0);
    U0LCR = 0x83;
       U0DLL = 0x06;
       U0DLM = 0x00;
       U0LCR = 0x03;
       U0FCR = 0x87;
       U0IER = 0x01;
    U0THR = c;
    while(*p)
        UART0_putc(*p);
           p++;
    uart0.td_cnt = 0;
    uart0.td_max = len;
           uart0.td_cnt++;
    INT8U err;
    pdata = pdata;
    UART0_init();
    do
        OSSemPend(uart0.rd_ok, 0, &err);
        UART0_send(1024);
        OSSemPend(uart0.td_ok, 0, &err);
        uart0.rd_cnt = 0;
    } while(1);
0331631 发表于 2010-10-21 22:29 | 显示全部楼层
先标记一下 慢慢看程序
金鱼木鱼 发表于 2010-10-21 22:57 | 显示全部楼层
dong_abc 发表于 2010-10-21 23:09 | 显示全部楼层
杜_U_ME 发表于 2010-10-22 22:59 | 显示全部楼层
学习下
七叶一枝花 发表于 2010-11-30 18:38 | 显示全部楼层
关注了。
bit6019 发表于 2010-11-30 23:49 | 显示全部楼层
学习了
wxbhlj 发表于 2011-7-13 13:54 | 显示全部楼层
楼主程序不错,若要配上注释看起来就轻松多了。
个人签名:30——驱动高手、流利的英语
107
