[资料]数字视频应用程序兼容性-IEEE 1394和USB设备
2455|1
 楼主| hehey 发表于 2010-7-6 11:49 | 显示全部楼层 |阅读模式
这是一个微软的**,但是是英文的
贴上一个摘要:
Abstract
This paper provides guidelines forapplication developers to follow so that digital video (DV) editingapplications can interface with the IEEE 1394and universal serial bus (USB) DV devices. For the most part, busdifferences are hidden from the application. Where differences wereunavoidable, this paper describes the mechanisms and interfaces that will allowthe application to discover and compensate for the bus-specificimplementations.
This paper provides guidelines forapplication developers to follow so that digital video editing applications caninterface with IEEE 1394and USB digital video devices. For the most part, bus differences are hiddenfrom the application. Where differences were unavoidable, this paper describesthe mechanisms and interfaces that will allow the application to discover andcompensate for the bus-specific implementations.
This information applies for thefollowing operating systems:
      Microsoft® Windows® XP
       Microsoft Windows Server™ 2003
       Microsoft Windows Vista™
The current version of this paper ismaintained on the Web at:
http://www.microsoft.com/whdc/
叫我童姥 发表于 2010-7-9 10:48 | 显示全部楼层
建议楼主去看看你的本本内存品牌去,尽量用和你本子一样品牌的,没有的话,金士顿的也行,我曾经把三星和金士顿的一起用.
