请教DMA1多通道使用问题
4345|4
 楼主| 古道122 发表于 2010-7-6 14:19 | 显示全部楼层 |阅读模式
DMA, TI, ST, IO, ni
想使用DMA1的多通道进行对TIM1的3个CCRx进行修改
设定1一个DMA1通道时,1个CCRx被修改了,没有问题,
但是在设定3个进行修改时,仍然只有1个CCRx被修改,其他两个就根本没有反应
具体设置如下,请教DMA1在使用多通道修改时有什么特殊讲究吗?
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define TIM1_CCR3_Address    0x40012C3C
#define TIM1_CCR1_Address    0x40012C34
#define TIM1_CCR2_Address    0x40012C38
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
DMA_InitTypeDef DMA_InitStructure;
u16 PWM_W_Buffer[2] = {1000,500};
u16 PWM_V_Buffer[2] = {1500,1000};
u16 PWM_U_Buffer[2] = {2500,2000};
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void DMA_Configuration(void);
void NVIC_Configuration(void);
/* Private functions ---------------------------------------------------------*/
* Function Name  : main
* Description    : Main program
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC configuration */
  NVIC_Configuration();
  /* GPIO Configuration */
  GPIO_Configuration();
  /* DMA Configuration */
  DMA_Configuration();
  /* TIM1 Peripheral Configuration ----------------------------------------*/
  /* Time Base configuration */
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned3;
  TIM_TimeBaseStructure.TIM_Period = 2249;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  /* Channel 3 Configuration in PWM mode */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 100;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  TIM_OC3Init(TIM1, &TIM_OCInitStructure);
  /* Channel 2 Configuration in PWM mode */
  TIM_OCInitStructure.TIM_Pulse = 200;
  TIM_OC2Init(TIM1, &TIM_OCInitStructure);
  /* Channel 1 Configuration in PWM mode */
  TIM_OCInitStructure.TIM_Pulse = 300;
  TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  /* TIM1 Update DMA Request enable */
  TIM_DMACmd(TIM1, TIM_DMA_Update, ENABLE);
  /* TIM1 counter enable */
  TIM_Cmd(TIM1, ENABLE);
  /* Main Output Enable */
  TIM_CtrlPWMOutputs(TIM1, ENABLE);
  while (1)
    if(GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_10) == 0){
      PWM_W_Buffer[0]=1000;
      PWM_W_Buffer[1]=800;
      PWM_U_Buffer[0]=2000;
      PWM_U_Buffer[1]=2500;
      PWM_V_Buffer[0]=2000;
      PWM_V_Buffer[1]=500;
    }                        //PWM_W_Buffer[2] = {1000,500};
                             //PWM_V_Buffer[2] = {1500,1000};
                             //PWM_U_Buffer[2] = {2500,2000};
    else{
      PWM_W_Buffer[1]=500;
      PWM_U_Buffer[0]=2500;
      PWM_U_Buffer[1]=2000;
      PWM_V_Buffer[0]=1500;
      PWM_V_Buffer[1]=1000;
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if (HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/4 */
    RCC_PCLK1Config(RCC_HCLK_Div4);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while (RCC_GetSYSCLKSource() != 0x08)
  /* TIM1, GPIOA and GPIOB clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 | RCC_APB2Periph_GPIOA |
                         RCC_APB2Periph_GPIOB, ENABLE);
  /* DMA clock enable */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
* Function Name  : GPIO_Configuration
* Description    : Configure the TIM1 Pins.
* Input          : None
* Output         : None
* Return         : None
  /* GPIOA Configuration: Channel 3 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_10 | GPIO_Pin_9 | GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* GPIOB Configuration: Channel 3N as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15 | GPIO_Pin_14 | GPIO_Pin_13;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* GPIOB Configuration: PB10 as input- low active */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
* Function Name  : DMA_Configuration
* Description    : Configures the DMA.
* Input          : None
* Output         : None
* Return         : None
  DMA_DeInit(DMA1_Channel2);
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)TIM1_CCR2_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)PWM_V_Buffer;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  DMA_InitStructure.DMA_BufferSize = 2;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel2, &DMA_InitStructure);
  /* DMA1 Channel5 enable */
  DMA_Cmd(DMA1_Channel2, ENABLE);
  /* DMA1 Channel5 Config */
  DMA_DeInit(DMA1_Channel3);
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)TIM1_CCR1_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)PWM_U_Buffer;
  DMA_Init(DMA1_Channel3, &DMA_InitStructure);
  DMA_Cmd(DMA1_Channel3, ENABLE);
  DMA_DeInit(DMA1_Channel1);
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)TIM1_CCR3_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)PWM_W_Buffer;
  DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  DMA_Cmd(DMA1_Channel1, ENABLE);
* Function Name  : NVIC_Configuration
* Description    : Configures Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
 楼主| 古道122 发表于 2010-7-6 16:37 | 显示全部楼层
又看了一下,似乎当有DMA1_Channel5在用的时候,就肯定会只响应这个通道的数据传输
当没有的时候,会响应其他的
这个和什么设置有关吗?
香水城 发表于 2010-7-6 16:39 | 显示全部楼层
在硬件上几个通道的操作肯定是串行的,不能同时操作。
xiaofei558008 发表于 2015-9-23 15:31 | 显示全部楼层
同问楼主一样的问题,求高手
xiaofei558008 发表于 2015-9-23 15:33 | 显示全部楼层
同问楼主一样的问题,求高手
