[疑难问答] 为什么接收不了信号
2764|2
 楼主| xiaomifan 发表于 2010-7-14 17:19 | 显示全部楼层 |阅读模式
我自己编了个红外发射和接收程序,可是硬件调试时发现接收不了信号,,查了好久都没有查出来,,请高手帮帮忙啊!
下面是我的发射信号和接收程序:请帮忙指点指点,谢谢了!!
发射信号程序:
//晶振24MHz,
//38kHz,周期T=26us,
#include <reg52.h>
#include <intrins.h>
#define uchar unsigned char
#define uint  unsigned int
sbit hongwai=P1^0;
void delay_12us(uchar g)
    while (g--);
void delay_1ms(uint k)
   uint i,j;
   for (i=k;i>0;i--)
     for (j=247;j>0;j--); //j取247时,1ms调用时相差1us
xinhao_fashe()
    uint m;  //195.50-194.50=1us
    for (m=1;m<=720;m++)
        {  hongwai=~hongwai; //196.50-195.50=1us
        delay_12us(1); //205.50-196.50=9us,返回去后有需要2.5us时间,故共定时9+2.5+1=12.5us
     _nop_();
      hongwai=0; //9408.0-9407.5=0.5us
      delay_1ms(4); //13392.5-9408.0=3883.5us
   for (m=1;m<=77;m++) // 4201.00-4200.00=1us
       hongwai=~hongwai; //4201.5-4201.00=0.5us
    delay_12us(1);  //4210.00-4201.5=8.0us
   hongwai=0;
   delay_1ms(1);
   for (m=1;m<=77;m++) //第二个1ms信号
       hongwai=~hongwai;
    delay_12us(1);
   hongwai=0; //1ms低电平间隔
   delay_1ms(1);
   for (m=1;m<=77;m++)  //第三个1ms信号
       hongwai=~hongwai;
    delay_12us(1);
   hongwai=0;   //2ms低电平间隔
   delay_1ms(2);  //1995.5us=2ms
   for (m=1;m<=77;m++)  //第四个1ms信号
       hongwai=~hongwai;
    delay_12us(1);
   delay_1ms(1);
   for (m=1;m<=320;m++)  //4ms截止码
       hongwai=~hongwai;
    delay_12us(1);
      delay_1ms(100);//26ms低电平间隔
void main()
   while (1)
      xinhao_fashe();
接收解码程序:
//12mhz
#include<reg52.h>
uchar wb=0,irr_b=0,da=0,p=0,s_flag=0;
uint a=0;
sbit beep=P3^4;
   uint i,j;
   for (i=k;i>0;i--)
     for (j=112;j>0;j--);
void ext_int0_isr(void) interrupt 0
  a=TH1*256+TL1;      //读取定时器的值
  if(irr_b==0)        //第一个中断
    irr_b=1;          //状态为:开始接收
    TH1=0x00;      //定时器清零
TL1=0x00;
  else if(irr_b==1)   //第二个以后的中断
      //a=TCNT1L;
      //判断是引导,还是数据
     if((11000<a)&&(a<14000))       //引导
      wb=0;                   //数据计数清零
   da=0;                   //数据清零
   TH1=0x00;            //定时器清零
   TL1=0x00;
     else if((1500<a)&&(a<2500))     //数据0
              wb++;
              da=(da<<1);
           TH1=0x00;
           TL1=0x00;
          else if((2500<a)&&(a<3500))    //数据1
                   wb++;
                da=(da<<1)+1;
                TH1=0x00;
                TL1=0x00;
if(wb==4)                    //数据长度够4位
    irr_b=0;                    //状态为停止接收
    wb=0;                       //数据计数清零
    p=da;
if (da==0x01)      s_flag=1;   //1号信号
else if (da==0x02) s_flag=2;   //2号信号
p=~p;
void init()
     TMOD=0x10;
     ET1=1;
     TR1=1;
     TH1=0;TL1=0;
     TF1=0;
  EX1=1;
  IT1=1;
     EA=1;
/*void fmq()
   beep=0;
   delay_1ms(100);
   beep=1;
   delay_1ms(100);
void main()
   P3=0xff;
   P2=0xff;
   P1=0xff;
   init();
   while(1)
   if (s_flag==1)
      P2=p;
   s_flag=0;
      EX1=0;
   EA=0;
      //fmq();
   EX1=1;
   EA=1;
   else
      if (s_flag==2)
      P2=p;
   s_flag=0;
   EX1=0;
      EA=0;
         //fmq();
   beep=0;
            delay_1ms(100);
            beep=1;
            delay_1ms(100);
      EX1=1;
      EA=1;
  P2=0xff;
beep是接蜂鸣器的,接收时发现蜂鸣器不响,这是什么缘故呢??请多指教啊!!
xiaohuai 发表于 2010-7-24 09:46 | 显示全部楼层
    while (g--);
这个延时的写法见得不是很多
 楼主| xiaomifan 发表于 2010-7-24 09:56 | 显示全部楼层
2# xiaohuai
问题不应该是这里吧
