看看这些警告是否可以做板
14944|13
hgjsj|  楼主 | 2010-7-17 13:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
quanzou| | 2010-7-17 15:40 | 只看该作者
无图无真象.请自行评估
hgjsj|  楼主 | 2010-7-20 07:25 | 只看该作者
Design Rule Verification Report
Date : 2010/7/20
Time : 6:50:16
Elapsed Time : 00:00:03
Filename : E:\Êý×ÖÐ¡Çø\µç·ͼ\NET4.0\Documents\PCB3.5.0.5.PcbDoc
Warnings : 0
Rule Violations : 66
Rule Violations Count
Room INTF3 (Bounding Region = (0mil, 0mil, 2000mil, 1000mil) (InComponentClass('INTF3')) 6
Room Core (Bounding Region = (0mil, 0mil, 2000mil, 1000mil) (InComponentClass('Core')) 42
Power Plane Connect Rule(Relief Connect )(Expansion=20mil) (Conductor Width=10mil) (Air Gap=10mil) (Entries=4) (All) 0
Clearance Constraint (Gap=7.874mil) (All),(All) 2
Width Constraint (Min=7.874mil) (Max=19.685mil) (Preferred=11.811mil) (All) 0
Hole Size Constraint (Min=1mil) (Max=100mil) (All) 14
Height Constraint (Min=0mil) (Max=1000mil) (Prefered=500mil) (All) 0
Un-Routed Net Constraint ( (All) ) 0
Short-Circuit Constraint (Allowed=No) (All),(All) 0
SMD Neck-Down Constraint (Percent=100%) (All) 2
Total 66
hgjsj|  楼主 | 2010-7-20 07:26 | 只看该作者
Room Definition Between Component on TopLayer And Rule on TopLayer
Back to top
hgjsj|  楼主 | 2010-7-20 07:27 | 只看该作者
Back to top
hgjsj|  楼主 | 2010-7-20 07:28 | 只看该作者
Text "1" (4480mil,6290mil) Top Layer Pad TED1-2-1(4560mil,6320mil) Multi-Layer
Text "1" (4930mil,4520mil) Top Layer Pad TED2-2-1(4960mil,4440mil) Multi-Layer
Back to top
Hole Size Constraint: Pad Free-4(2132mil,3140mil) Multi-Layer
Hole Size Constraint: Pad Free-3(7772mil,3140mil) Multi-Layer
Hole Size Constraint: Pad Free-2(7772mil,7590mil) Multi-Layer
Hole Size Constraint: Pad Free-1(2132mil,7590mil) Multi-Layer
Hole Size Constraint: Pad U2-(6456.38mil,5990.236mil) Multi-Layer
Hole Size Constraint: Pad U2-(3503.624mil,5990.236mil) Multi-Layer
Hole Size Constraint: Pad U2-(6456.38mil,4769.764mil) Multi-Layer
Hole Size Constraint: Pad U2-(3503.624mil,4769.764mil) Multi-Layer
Hole Size Constraint: Pad J4-1-3(2304.094mil,6640mil) Multi-Layer
Hole Size Constraint: Pad J4-1-1(2560mil,6640mil) Multi-Layer
Hole Size Constraint: Pad U1-6-(6849.804mil,7329.016mil) Multi-Layer
Hole Size Constraint: Pad U1-6-(6399.804mil,7330.08mil) Multi-Layer
Hole Size Constraint: Via (6120mil,3200mil) Top Layer to Bottom Layer
Hole Size Constraint: Via (5636.064mil,3200mil) Top Layer to Bottom Layer
Back to top
SMD Neck-Down Constraint Between Pad on TopLayer And Track on TopLayer
Back to top
hgjsj|  楼主 | 2010-7-20 07:35 | 只看该作者
请各位前辈指教,每段警告的含义,谢谢
acute1110| | 2010-7-20 09:32 | 只看该作者
嘎多,自己看帮助吧,这样问题大了,不是吓你,可能板子做出来是废板
hgjsj|  楼主 | 2010-7-20 15:18 | 只看该作者
楼上的兄弟,如何查询这些帮助
hgjsj|  楼主 | 2010-7-20 18:16 | 只看该作者
解决了,嘿嘿~~
黄jiajia| | 2010-7-21 16:59 | 只看该作者
wang668| | 2010-7-23 17:50 | 只看该作者
呵呵
zzk529| | 2015-6-28 18:03 | 只看该作者
hgjsj 发表于 2010-7-20 18:16
解决了,嘿嘿~~
怎么解决的   呢
