[产品供应]
Full digital and full analog + perfect digital IC-CV2880
566|0
aa6777347|  楼主 | 2017-7-3 14:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Reference: support 5 mega-pixel 2K video converting IC
In 2014, the first volume production CV2880 came into market. This SOC single chip is high image quality, great function for camera and image areas. It can support most digital/analog signal input/output. The internal Scaler and internal storage has small size and low power dissipation, so it suits to security and protection monitoring, visual presenter, industrial camera, high-tech video converting etc.
Specification of CV2880:
Digital input supports:
  Over 5mega-pixel(2596x1944) CMOS sensor bayer data(RAW Data)input
  8 Bits BT656/BT601
  8 Bits/16Bits BT1120
  8 Bits/16Bits YC422
  24 Bits RGB444 /YUV444
  16/24/32 Bits TTL
  supporting standard and HD digital input
  supporting interlaced scanning or progressive scanning input
  the biggest input frequency 165MHz
  supporting automatically input detection
Digital output supports:
  8Bits BT.656/BT.601
  8Bits /16 Bits BT.1120
  16Bits YC422
  24Bits RGB444/YUV444
  16/24/32Bits TTL
  The max clock over 165MHz
Analog output signal supports:
  Three lines 10 bits DACs
  supporting one line of CVBS and one line of S-Video output
  supporting three lines of CVBS output at the same time
  supporting VGA output & maximum 1920x1080@60 or 2560x1440@30
  supporting YPBPR(SOY)output & maximum 1080P60
Intelligent image processing:
  supporting Black and White level expansion
  Flesh Tone Correction
  Horizontal Peaking
  Dynamic luminance signal
  Dynamic chroma
  ACCE
  chroma,contrast ratio,saturability,tonal adjustment
  Gamma Correction
  AE,AF,AWB
  PVA,parallel Mirror
  Freeze
  same screen comparison,DVI
  industrial customization
De-interlacing
  support NTSC/PAL and HDTV 1080I input and interlaced scanning to progressive scanning
  film pattern supports 3:2 and 2:2 pull-down
  technology of reducing noise with automatically Adaptating 2D and 3D
Scaling
  total coding scaling
  individual Horizontal and vertical scaling
  three lines buffer + developed scaling to make image quality higher 30% than normal IC
OSD
  high quality coding menu of embeddedstorage
  1,2 and 4-bit per pixel character cells
  coding the size of character
  Horizontal menu and vertical extension
  flickering menu technology
  diaphaneity rejection and menu superposition
  8 sets cross curve moving with pixel in full screen
  support custom 16x16 bitmap font
Embedded DDR storage and control pattern
FRC (Frame Rate Conversion) supports any FRC converting
Two sets of Slave I2C interface
Feature:
  1.8V/3.3V, average of power dissipation 260MA
  Internal ESD/TVS against 8000V over 4 times than normal IC
   Continue working in -40 degree to 110 degree environment
  encapsulation is 80PIN QFP, separation distance is 0.5PIN
   size is 12x12 mm
CV2880 continues to develop since it was for sale. This IC must be the best product in video converting area. Chipav has a whole set of solution about CV2880, and most sample of SCH, PCB, BOM are for free. If you are interested in our product, please contact with us and get more detail!
Don't wait. Just contact with Jax Lee
Web: http://www.chipav.com                Skype: 454263933@qq.com
Fax: +86 755-27721242                        Email: jax@chipav.com
QQ:549293405
Address: 205C, Hongtaifu D Building, JianAn 1st road 514, BaoAn 34 District, ShenZhen, PRC (P.C. 518100)
个人签名:芯视音李工:18665321060 QQ:549293405 专注视频转换方案及IC
107
