C5505不能正常调试
1686|21
 楼主| sz_xjx 发表于 2017-7-13 17:41 | 显示全部楼层 |阅读模式
使用的是XDS100仿真器,板子自制,之前一直好用,但突然无法DEBUG,显示
Error connecting to the target:
(Error -1023 @ 0x5F)
Requested JTAG operation failed. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK).
(Emulation package 5.1.507.0)
但通过XDS100的Test Connection 的测试结果为
[Start: Texas Instruments XDS100v2 USB Emulator_0]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\Users\szup\AppData\Local\TEXASI~1\CCS\
ti\0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'jioserdesusb.dll'.
The library build date was 'May 21 2014'.
The library build time was '17:19:59'.
The library package version is '5.1.507.0'.
The library component version is '35.34.40.0'.
The controller does not use a programmable FPGA.
The controller has a version number of '4' (0x00000004).
The controller has an insertion length of '0' (0x00000000).
This utility will attempt to reset the controller.
This utility has successfully reset the controller.
-----[Print the reset-command hardware log-file]-----------------------------
The scan-path will be reset by toggling the JTAG TRST signal.
The controller is the FTDI FT2232 with USB interface.
The link from controller to target is direct (without cable).
The software is configured for FTDI FT2232 features.
The controller cannot monitor the value on the EMU[0] pin.
The controller cannot monitor the value on the EMU[1] pin.
The controller cannot control the timing on output pins.
The controller cannot control the timing on input pins.
The scan-path link-delay has been set to exactly '0' (0x0000).
-----[The log-file for the JTAG TCLK output generated from the PLL]----------
There is no hardware for programming the JTAG TCLK frequency.
-----[Measure the source and frequency of the final JTAG TCLKR input]--------
There is no hardware for measuring the JTAG TCLK frequency.
-----[Perform the standard path-length test on the JTAG IR and DR]-----------
This path-length test uses blocks of 512 32-bit words.
The test for the JTAG IR instruction path-length succeeded.
The JTAG IR instruction path-length is 38 bits.
The test for the JTAG DR bypass path-length succeeded.
The JTAG DR bypass path-length is 1 bits.
-----[Perform the Integrity scan-test on the JTAG IR]------------------------
This test will use blocks of 512 32-bit words.
This test will be applied just once.
Do a test using 0xFFFFFFFF.
Scan tests: 1, skipped: 0, failed: 0
Do a test using 0x00000000.
Scan tests: 2, skipped: 0, failed: 0
Do a test using 0xFE03E0E2.
Scan tests: 3, skipped: 0, failed: 0
Do a test using 0x01FC1F1D.
Scan tests: 4, skipped: 0, failed: 0
Do a test using 0x5533CCAA.
Scan tests: 5, skipped: 0, failed: 0
Do a test using 0xAACC3355.
Scan tests: 6, skipped: 0, failed: 0
All of the values were scanned correctly.
The JTAG IR Integrity scan-test has succeeded.
-----[Perform the Integrity scan-test on the JTAG DR]------------------------
The JTAG DR Integrity scan-test has succeeded.
[End: Texas Instruments XDS100v2 USB Emulator_0]
请大家帮忙看看这是什么问题,十分感谢!
zhangmangui 发表于 2017-7-17 20:42 来自手机 | 显示全部楼层
怎么会有这么多信息
zhangmangui 发表于 2017-7-17 20:43 来自手机 | 显示全部楼层
应该是目标板出问题了。看看clkout输出 时钟的复位等有问题没
fentianyou 发表于 2017-7-17 23:10 | 显示全部楼层
芯片电源是否正常?
xiaoyaodz 发表于 2017-7-17 23:10 | 显示全部楼层
设备管理器里面是否还有仿真器的设备?
febgxu 发表于 2017-7-17 23:11 | 显示全部楼层
一般都是使用的现成的仿真器,这个自制的不知道什么问题
你使用的是XDS100V?哪个版本的
pixhw 发表于 2017-7-17 23:13 | 显示全部楼层
仿真其它开发板没有问题吧。
uiint 发表于 2017-7-17 23:13 | 显示全部楼层
DSP板子还能正常运行吗?
mmbs 发表于 2017-7-17 23:14 | 显示全部楼层
能够下载程序吗?
lihuami 发表于 2017-7-17 23:14 | 显示全部楼层
使用的是什么编译器调试的?
aspoke 发表于 2017-7-17 23:14 | 显示全部楼层
之前能够正常使用仿真器和开发板吗?
plsbackup 发表于 2017-7-17 23:15 | 显示全部楼层
换个其他的开发板先确定仿真器和驱动没有问题。
fentianyou 发表于 2017-7-17 23:15 | 显示全部楼层
这个看看仿真器是否还能识别出来?
xiaoyaodz 发表于 2017-7-17 23:15 | 显示全部楼层
如果是驱动的问题,重新安装驱动就解决了。
febgxu 发表于 2017-7-17 23:15 | 显示全部楼层
可能系统不能兼容驱动了。
uiint 发表于 2017-7-17 23:15 | 显示全部楼层
先前下载的代码是否能够执行?
mmbs 发表于 2017-7-17 23:15 | 显示全部楼层
升级一下CCS软件试试。
lihuami 发表于 2017-7-17 23:15 | 显示全部楼层
推荐CCS的软件调试试试。
aspoke 发表于 2017-7-17 23:15 | 显示全部楼层
如果之前正常说明后面就是硬件问题。
