[经验分享] 矩阵按键应用
2532|0
 楼主| xiaohuai 发表于 2010-7-24 10:42 | 显示全部楼层 |阅读模式
硬件要求:
矩阵按键连接至P3口;
数码管段选和位选各用1个锁存器;
段选连P2^6,位选连P2^7,用P0口控制。
C程序:
#include <reg52.h>
#define uint unsigned int
#define uchar unsigned char
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0};
uchar num,temp;
void delay(uint z)
uint x,y;
for(x=0;x<z;x++)
  for(y=0;y<117;y++);
}void keyscan();
void xs(uchar num1);
void init();
void main()
init();
while(1)
  keyscan();
  xs(num);
void init()
num=17;
dula=1;
P0=0;
dula=0;
wela=1;
P0=0xc0;
wela=0;
void keyscan()
P3=0xfe;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
  delay(5);
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
  switch(temp)
    case 0xe0:num=1;
    break;
    case 0xd0:num=2;
    break;
    case 0xb0:num=3;
    break;
    case 0x70:num=4;
    break;
P3=0xfd;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
  delay(5);
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
  switch(temp)
    case 0xe0:num=5;
    break;
    case 0xd0:num=6;
    break;
    case 0xb0:num=7;
    break;
    case 0x70:num=8;
    break;
P3=0xfb;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
  delay(5);
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
  switch(temp)
    case 0xe0:num=9;
    break;
    case 0xd0:num=10;
    break;
    case 0xb0:num=11;
    break;
    case 0x70:num=12;
    break;
P3=0xf7;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
  delay(5);
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
  switch(temp)
    case 0xe0:num=13;
    break;
    case 0xd0:num=14;
    break;
    case 0xb0:num=15;
    break;
    case 0x70:num=16;
    break;
void xs(uchar num1)
dula=1;
P0=table[num1-1];
dula=0;
