[资料分享] TI新品推荐-OPAx196
674|3
 楼主| xyz549040622 发表于 2017-7-26 18:11 | 显示全部楼层 |阅读模式
描述
The OPAx196 family (OPA196, OPA2196, and OPA4196) is a new generation of 36-V,        rail-to-rail e-trim™ operational amplifiers (op amps).
These devices offer very low offset voltage (±25 µV, typical), drift (±0.5 µV/°C,        typical), and low bias current (±5 pA, typical) combined with very low quiescent current (140        µA/channel, typical) across the entire output range.
Unique features, such as differential input-voltage range to the supply rail, high output        current (±65 mA), and high capacitive load drive of up to 1 nF make the OPAx196 a robust,        high-performance operational amplifier for high-voltage industrial applications.
The OPAx196 family of op amps is available in standard packages and is specified from        –40°C to +125°C.
特性
  • Low Offset Voltage: ±100 µV (maximum)
  • Low Offset Voltage Drift:        ±0.5 µV/°C (typical)
  • Low Bias Current: ±5 pA        (typical)
  • High Common-Mode Rejection: 140 dB
  • Low Noise: 15        nV/√Hz at 1 kHz
  • Rail-to-Rail Input and        Output
  • Differential Input Voltage Range to Supply Rail
  • Wide        Bandwidth: 2.5-MHz GBW
  • Low Quiescent Current: 140 µA per Amplifier        (typical)
  • Wide Supply: ±2.25 V to ±18 V, 4.5 V to 36        V
  • EMI/RFI Filtered Inputs
  • High Capacitive Load Drive        Capability: 1 nF
  • Industry Standard Packages:
    • Single in        SOIC-8, SOT-5, and VSSOP-8
    • Dual in SOIC-8 and VSSOP-8
    • Quad        in SOIC-14, TSSOP-14, and QFN-16
 楼主| xyz549040622 发表于 2017-7-26 18:12 | 显示全部楼层
comeon201208 发表于 2017-7-26 22:22 | 显示全部楼层
这是电压型放大器的资料介绍
个人签名:qq群: 嵌入式系统arm初学者 224636155←← +→→点击-->小 i 精品课全集,21ic公开课~~←←→→点击-->小 i 精品课全集,给你全方位的技能策划~~←←
2841
