[STM32F0] stup Programming failed. Check that the device is erased before programming
4099|2
 楼主| happytong 发表于 2017-7-27 16:02 | 显示全部楼层 |阅读模式
stup  用的是st-link烧程序时出现  Programming failed. Check that the device is erased before programming 跪求原因
mmuuss586 发表于 2017-7-27 18:52 | 显示全部楼层
插拔仿真器,还有板子重新上电看看;
还不行的话,换块板子测试下;
963499364 发表于 2017-10-13 15:36 | 显示全部楼层
芯片里有程序  擦除就好了
