[应用相关]
【转】STM32手册中找不到的寄存器说明
1058|0
Rollo|  楼主 | 2017-7-31 16:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天在STM32参考手册中找,滴达时钟寄存器怎么也找不到,后来在网上收到,心情有点不爽
本文转自网上,如果原作看到的话请留言,我会把出处加上,谢谢!
在STM32中用到了Cortex-M3定义的三组寄存器,有关这三组寄存器的说明不在STM32的技术手册中,需要参考ARM公司发布的Cortex-M3 Technical Reference Manual (r2p0)。
在STM32的固件库中定义了三个结构体与这三个寄存器组相对应,这三个结构体与ARM手册中寄存器的对应关系如下:
一、NVIC寄存器组
STM32的固件库中有如下定义:
typedef struct
  vu32 ISER[2];
  u32 RESERVED0[30];
  vu32 ICER[2];
  u32 RSERVED1[30];
  vu32 ISPR[2];
  u32 RESERVED2[30];
  vu32 ICPR[2];
  u32 RESERVED3[30];
  vu32 IABR[2];
  u32 RESERVED4[62];
  vu32 IPR[11];
} NVIC_TypeDef;
它们对应ARM手册中的名称为
ISER = Interrupt Set-Enable Registers
ICER = Interrupt Clear-Enable Registers
ISPR = Interrupt Set-Pending Register
ICPR = Interrupt Clear-Pending Register
IABR = Active Bit Register
IPR = Interrupt Priority Registers
每个寄存器有240位,以Interrupt Set-Enable Registers说明,ISER[0]对应中断源0~31,ISER[1]对应中断源32~63,STM32只有60个中断源,所以没有ISER[2:7]。
参考STM32技术参考手册中的中断向量表,中断源的位置为:
位置0 - WWDG = Window Watchdog interrupt
位置1 - PVD = PVD through EXTI Line detection interrupt
位置2 - TAMPER = Tamper interrupt
位置58 - DMA2_Channel3 = DMA2 Channel3 global interrupt
位置59 - DMA2_Channel4_5 = DMA2 Channel4 and DMA2 Channel5 global interrupts
二、系统控制寄存器组
STM32的固件库中有如下定义:
typedef struct
  vuc32 CPUID;
  vu32 ICSR;
  vu32 VTOR;
  vu32 AIRCR;
  vu32 SCR;
  vu32 CCR;
  vu32 SHPR[3];
  vu32 SHCSR;
  vu32 CFSR;
  vu32 HFSR;
  vu32 DFSR;
  vu32 MMFAR;
  vu32 BFAR;
  vu32 AFSR;
} SCB_TypeDef; /* System Control Block Structure */
它们对应ARM手册中的名称为
CPUID = CPUID Base Register
ICSR = Interrupt Control State Register
VTOR = Vector Table Offset Register
AIRCR = Application Interrupt/Reset Control Register
SCR = System Control Register
CCR = Configuration Control Register
SHPR = System Handlers Priority Register
SHCSR = System Handler Control and State Register
CFSR = Configurable Fault Status Registers
HFSR = Hard Fault Status Register
DFSR = Debug Fault Status Register
MMFAR = Mem Manage Address Register
BFAR = Bus Fault Address Register
AFSR = Auxiliary Fault Status Register
三、系统时钟寄存器组
STM32的固件库中有如下定义:
typedef struct
  vu32 CTRL;
  vu32 LOAD;
  vu32 VAL;
  vuc32 CALIB;
} SysTick_TypeDef;
它们对应ARM手册中的名称为
CTRL = SysTick Control and Status Register
LOAD = SysTick Reload Value Register
VAL = SysTick Current Value Register
CALIB = SysTick Calibration Value Register
