[STM32L0] 停止模式恢复的问题
1057|3
 楼主| nuc990 发表于 2017-8-7 21:12 | 显示全部楼层 |阅读模式
pi, IO, GPIO, gp, ST
   进入停止模式之前调用了:
SystemPower_Config()函数
static void SystemPower_Config(void)
  /* Enable Ultra low power mode */
  HAL_PWREx_EnableUltraLowPower();
  /* Enable the fast wake up from Ultra low power mode */
  HAL_PWREx_EnableFastWakeUp();
  /* Select HSI as system clock source after Wake Up from Stop mode */
  __HAL_RCC_WAKEUPSTOP_CLK_CONFIG(RCC_STOP_WAKEUPCLOCK_HSI);
  /* Enable GPIOs clock */
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  /* Configure all GPIO port pins in Analog Input mode (floating input trigger OFF) */
  GPIO_InitStructure.Pin = GPIO_PIN_All;
  GPIO_InitStructure.Mode = GPIO_MODE_ANALOG;
  GPIO_InitStructure.Pull = GPIO_NOPULL;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStructure);
  HAL_GPIO_Init(GPIOB, &GPIO_InitStructure);
  HAL_GPIO_Init(GPIOC, &GPIO_InitStructure);
  HAL_GPIO_Init(GPIOD, &GPIO_InitStructure);
  HAL_GPIO_Init(GPIOH, &GPIO_InitStructure);
  /* Disable GPIOs clock */
  __HAL_RCC_GPIOA_CLK_DISABLE();
  __HAL_RCC_GPIOB_CLK_DISABLE();
  __HAL_RCC_GPIOC_CLK_DISABLE();
  __HAL_RCC_GPIOD_CLK_DISABLE();
  __HAL_RCC_GPIOH_CLK_DISABLE();
然后进入: HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_STOPENTRY_WFI);
SystemClockConfig_STOP();
唤醒正常,但是重新初始化串口(串口里面初始化了GPIO和CLK),却无法打印,这是为什么?
651471519 发表于 2017-8-21 21:48 | 显示全部楼层
你可以参考一下。官方的低功耗的串口的使用方法
arccosine 发表于 2017-8-23 21:24 | 显示全部楼层
都搞死了  怎么能用!
zhuotuzi 发表于 2017-8-24 09:54 | 显示全部楼层
时钟全关闭?
