[STM8] stm8l152 adc初始化与引脚选择
13380|26
 楼主| yilichen 发表于 2010-8-7 21:38 | 显示全部楼层 |阅读模式
请各位帮帮忙:
下面是我对ADC的初始化,但是不能工作,现在还不会做引脚的选择。
ADC单次转换初始化
void ADCInit(void)
  CLK_PCKENR2 |= (1<<0);
  //ADC1_CR1 = 0x09;//单次转换,启动ADC(是否要启动ADC,待定),允许转换完成中断
// ADC1_CR2 = 0x58;//时钟不分频,下降沿触发,使用第3个触发(定时器2)4个采样时钟
  //RI_IOSR1 |= (1<<1);
  //RI_ASCR1 &= (~(1<<1));
  //RI_IOCMR1 |= (1<<1);
  ADC1_CR1 = 0x00;
  ADC1_CR2 = 0;
  ADC1_CR3 = 24;
  //ADC1_TRIGR4 = 24;
  ADC1_TRIGR1 = 0;
  ADC1_SQR1 = 0x80;//OFF DMA
  ADC1_CR1 = 0x01;
  ADC1_CR1 |= (1<<1);
  while(!(ADC1_SR & (1<<0)));
  //ADC1_CR3 = 0;//默认选择0通道
求一下可用的ADC例程或是请大家赐教一下如何使用ADC。谢谢!
我的邮箱:123456chenyili@163.com
IJK 发表于 2010-8-9 13:36 | 显示全部楼层
这是我的部分代码,使用PC7(ADC_3)做AD输入,使用了STM8L的库,可以工作,供参考:
  // Enable ADC clock
  CLK->PCKENR2 |= CLK_PCKENR2_ADC;
  // Set PC7 as Input floating no INT - ADC_3
  GPIO_Init(GPIOC, GPIO_Pin_7, GPIO_Mode_In_FL_No_IT);
  // de-initialize ADC
  ADC_DeInit();
  // ADC configuration ---------------------------------------//
  ADC_Init(ADC_Channel_3, ADC_ConversionMode_Single,
           ADC_Resolution_12Bit, ADC_Prescaler_1);
  // SampleTime: 159 cycles
  ADC_SamplingTimeConfig(ADC_Group_SlowChannels, ADC_SamplingTimeCycles_159);
  // enable ADC
  ADC->CR1 |= ADC_CR1_ADON;
  // start ADC convertion by software
  ADC->CR1 |= ADC_CR1_START;
  // wait until end-of-covertion
  while( ADC_GetFlagStatus(ADC_FLAG_EOC) == 0 )
  // read ADC convertion result
  value = ADC_GetConversionValue();
zhangyong1818 发表于 2010-8-9 14:52 | 显示全部楼层
2楼的程序我试了一下 ,不行啊!死在while(ADC_Getflagstatus(ADC_FLAG_EOC)==0);  估计AD就没转换,怎么会一直都不结束转换!疑问
zhangyong1818 发表于 2010-8-9 17:00 | 显示全部楼层
GPIO_Init(GPIOD,GPIO_Pin_4,GPIO_Mode_In_FL_No_IT );
                /*Enable ADC1 clock */
                CLK_PeripheralClockConfig(CLK_Peripheral_ADC1, ENABLE);
                /*初始化AD*/
                ADC_DeInit(ADC1);
                //CLK->PCKENR2 |= CLK_PCKENR2_ADC;
                /* Initialize and configure ADC1 */
                ADC_Init(ADC1, ADC_ConversionMode_Single,
                ADC_SamplingTimeConfig(ADC1, ADC_Group_SlowChannels,
                                       ADC_SamplingTime_384Cycles);
                                /* Enable ADC1 Channel 10*/
                ADC_ChannelCmd(ADC1,ADC_Channel_10, ENABLE);
                //ADC_DMACmd(ADC1,ENABLE);
                ADC_SoftwareStartConv(ADC1);
                ADC_Cmd(ADC1, ENABLE);
zhangyong1818 发表于 2010-8-9 17:01 | 显示全部楼层
不行啊 ,求高人指点!
 楼主| yilichen 发表于 2010-8-9 21:09 | 显示全部楼层
先谢过各位。我试试。
zhangyong1818 发表于 2010-8-10 09:05 | 显示全部楼层
个人感觉 这个芯片的AD转化不准确!
                ADC_DeInit(ADC1);
                //ADC1->SQR[regindex] |= (uint8_t)(ADC_Channels);
                //ADC_ITConfig(ADC1, ADC_IT_EOC, DISABLE);
                ADC_VrefintCmd(ENABLE);
                ADC_Cmd(ADC1, ENABLE);这是AD的初始化
这是主程序所用的内容:
                                               //delay(1000);
                        while(ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC) == 0 );
                             j=ADC_GetConversionValue(ADC1);
                        if(j>0x00FF)
                                  ADC_ClearFlag(ADC1,ADC_FLAG_EOC);
                                        start_work( );
                                        //ADC_ClearITPendingBit(ADC1, ADC_IT_EOC);
zhangyong1818 发表于 2010-8-10 09:22 | 显示全部楼层
刚开始我把这句:ADC_SoftwareStartConv(ADC1);放在初始化里面了。我死活读取到AD数据寄存器里面的值;很是郁闷,最后我把上面那句开始转换 换个位置,可以读取值,但是不准确。我认为既然是单次转换,一次转换结束他也应该把一次转换的结果存到计数器里面等待读取。然后给个结束标志!单次转换应该很简单啊,但是很不理想!
zhangyong1818 发表于 2010-8-10 09:48 | 显示全部楼层
ADC_DMACmd(ADC1,DISABLE);加上这一句就好多了  呵呵!
IJK 发表于 2010-8-10 11:05 | 显示全部楼层
根据我的实际使用,stm8l152的AD精度挺高。
 楼主| yilichen 发表于 2010-8-10 11:39 | 显示全部楼层
请问10楼,有没有直接操作寄存器的ADC例程。有的话,给我发一份。
我的邮箱:chenyili2007@qq.com
谢谢。
 楼主| yilichen 发表于 2010-8-10 11:43 | 显示全部楼层
请问zhangyong1818可否将你实验的程序发一份给我。谢谢。
zhangyong1818 发表于 2010-8-10 12:46 | 显示全部楼层
单步执行程序时我只能看到ADC中高位DRH的值为0d   DRL值为xx:   不知道为什么?
zhangyong1818 发表于 2010-8-10 13:50 | 显示全部楼层
经过同事的指点,我把AD转换的结果在LCD显示出来了,挺准确,冤枉芯片了。不过在初始化配置上还是存在疑问。。。。。。。。
CrazyST 发表于 2011-3-29 17:32 | 显示全部楼层
楼主。
这个通道是用来选择模拟看门狗通道的!不信你再看看手册。
[ADC的转换通道在SQRx寄存器里选择!无论是单次模式还是连续模式!
xfh168168 发表于 2011-5-17 08:31 | 显示全部楼层
15楼正解
yinyangdianzi 发表于 2011-5-20 13:17 | 显示全部楼层
一大堆代码,,看不懂
avb888 发表于 2011-5-26 16:15 | 显示全部楼层
请问哪位高手有STM8L151 ADC应用实例?
fjsnhxzsx 发表于 2011-8-3 10:14 | 显示全部楼层
问下大伙,有没有STM8L的技术交流群?若无的话,建议哪位高手建个群,这样可以方便大家学习交流哦
aihe 发表于 2011-8-3 16:36 | 显示全部楼层
库文件里面有例程
