perl port to winbond uClinux?
3053|3
 楼主| 火箭球迷 发表于 2010-8-12 10:15 | 显示全部楼层 |阅读模式
請問各位
perl能夠port到winbond uClinux 上使用嗎?
我在menuconfig中選取perl
compiler出現下列訊息
sv.c: In function `Perl_sv_gets':
sv.c:4419: structure has no member named `_IO_read_end'
sv.c:4419: structure has no member named `_IO_read_ptr'
sv.c:4435: structure has no member named `_IO_read_ptr'
sv.c:4473: structure has no member named `_IO_read_ptr'
sv.c:4486: structure has no member named `_IO_read_end'
sv.c:4486: structure has no member named `_IO_read_ptr'
sv.c:4487: structure has no member named `_IO_read_ptr'
sv.c:4514: structure has no member named `_IO_read_ptr'
make[2]: *** [sv.o] Error 1
make[2]: Leaving directory `/home/minyi/snmpAdaptor/code/uClinux-dist/user/perl'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/minyi/snmpAdaptor/code/uClinux-dist/user'
make: *** [user_only] Error 2
dfsa 发表于 2010-8-12 15:22 | 显示全部楼层
这个没看太明白
pkat 发表于 2010-8-13 14:06 | 显示全部楼层
文字太少,代码太多,看起来有点费劲
秋天落叶 发表于 2010-8-13 14:48 | 显示全部楼层
perl可以port到winbond uClinux 上使用,你的错误提示有点奇怪
个人签名:姚明的铁杆球迷
150
