nichia公司最新半导体发光二极管专利
2306|2
 楼主| 丁韵灵均 发表于 2010-8-24 14:17 | 显示全部楼层 |阅读模式
SEMICONDUCTOR LIGHT-EMITTING DEVICE
这是业界巨头nichia公司在8月19号拿到的最新专利技术。摘要如下:
(EN) A semiconductor light-emitting device wherein higher luminous efficiency can be achieved.? Specifically disclosed is a semiconductor light-emitting device (10) comprising: a package (11) which contains at least a first insulating layer, a second insulating layer, conductive wires (14a, 14b) formed on the surface of the first insulating layer and an inner-layer wire arranged between the first insulating layer and the second insulating layer; a semiconductor light-emitting element (12) mounted on the first insulating layer of the package (11); and a sealing member (13) so formed on the package (11) as to cover the semiconductor light-emitting element (12).? The inner-layer wire is so formed as to avoid the region right below the peripheral region of the semiconductor light-emitting element (12).
有从事LED技术技术开发的人员可以参考一下具体资料:
http://so.5ipatent.com/PatentDetails.aspx?patentID=c5ba941a-1d06-4fb5-844b-25e17137413e&patentClass=128
严复古仿古 发表于 2010-8-24 15:05 | 显示全部楼层
nichia的实力已经越来越弱了,不过瘦死的骆驼比马大。中国LED产业的专利风险仍然很大!
fringe 发表于 2010-8-25 08:16 | 显示全部楼层
英语--理解不能...
