// MSP430F5438 Demo - Timer_A3, Toggle P1.02.1-3, Cont. Mode ISR, 32kHz ACLK
// Description: Use Timer1_A CCRx units and overflow to generate four
// independent timing intervals. For demonstration, CCR0, CCR1 and CCR2
// output units are optionally selected with port pins P2.1, P2.2 and P2.3
// in toggle mode. As such, these pins will toggle when respective CCRx
// registers match the TAR counter. Interrupts are also enabled with all
// CCRx units, software loads offset to next interval only - as long as
// the interval offset is added to CCRx, toggle rate is generated in
// hardware. Timer1_A overflow ISR is used to toggle P1.0 with software.
// Proper use of the TAIV interrupt vector generator is demonstrated.
// ACLK = TACLK = 32kHz, MCLK = SMCLK = default DCO ~1.045MHz
// As coded and with TACLK = 32768Hz, toggle rates are:
// P2.1= CCR0 = 32768/(2*4) = 4096Hz
// P2.2= CCR1 = 32768/(2*16) = 1024Hz
// P2.3= CCR2 = 32768/(2*100) = 163.84Hz
// P1.0= overflow = 32768/(2*65536) = 0.25Hz
// MSP430F5438
// --|RST |
// | P2.1/TA1.0|--> CCR0
// | P2.2/TA1.1|--> CCR1
// | P2.3/TA1.2|--> CCR2
// | P1.0|--> Overflow/software
// | P1.0|--> LED
// M Smertneck / W. Goh
// Texas Instruments Inc.
// September 2008
// Built with CCE Version: 3.2.2 and IAR Embedded Workbench Version: 4.11B
#include "msp430x54x.h"
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P11DIR |= 0x07; // ACLK, MCLK, SMCLK set out to pins
P11SEL |= 0x07; // P11.0,1,2 for debugging purposes.
P2SEL |= 0x0E; // P2.1 - P2.3 option select 0000 1110
P2DIR |= 0x0E; // P2.1 - P2.3 outputs
P4DIR |= 0x10; // P1.0 - Outputs
TA1CCTL0 = OUTMOD_4 + CCIE; // CCR0 toggle, interrupt enabled
TA1CCTL1 = OUTMOD_4 + CCIE; // CCR1 toggle, interrupt enabled
TA1CCTL2 = OUTMOD_4 + CCIE; // CCR2 toggle, interrupt enabled
TA1CTL = TASSEL__ACLK + MC__CONTINOUS + TACLR + TAIE; // ACLK, contmode, clear TAR,
// interrupt enabled
__bis_SR_register(LPM3_bits + GIE); // Enter LPM3, interrupts enabled
__no_operation(); // For debugger
// Timer1 A0 interrupt service routine
#pragma vector=TIMER1_A0_VECTOR
__interrupt void Timer_A0 (void)
TA1CCR0 += 4; // Add Offset to CCR0
// Timer_A3 Interrupt Vector (TAIV) handler
#pragma vector=TIMER1_A1_VECTOR
__interrupt void TIMER1_A1_ISR(void)
switch(__even_in_range(TA1IV,14))
case 0: break;
case 2: TA1CCR1 += 16; // Add Offset to CCR1
break;
case 4: TA1CCR2 += 100; // Add Offset to CCR2
break;
case 6: break; // CCR3 not used
case 8: break; // CCR4 not used
case 10: break; // CCR5 not used
case 12: break; // Reserved not used
case 14: P4OUT ^= 0x10; // overflow
break;
default: break;
