[matlab] 范例:opencore组织RISCMCU IP Core全套最新代码 _sr
2278|0
 楼主| wangjun88 发表于 2010-8-27 10:03 | 显示全部楼层 |阅读模式
---- WISHBONE RISCMCU IP Core ----
---- This file is part of the RISCMCU project ----
---- http://www.opencores.org/projects/riscmcu/ ----
---- Description ----
---- Implementation of a RISC Microcontroller based on Atmel AVR ----
---- AT90S1200 instruction set and features with Altera Flex10k20 FPGA. ----
---- Author(s): ----
---- - Yap Zi He, yapzihe@hotmail.com ----
---- Copyright (C) 2001 Authors and OPENCORES.ORG ----
---- This source file may be used and distributed without ----
---- restriction provided that this copyright statement is not ----
---- removed from the file and that any derivative work contains ----
---- the original copyright notice and the associated disclaimer. ----
---- This source file is free software; you can redistribute it ----
---- and/or modify it under the terms of the GNU Lesser General ----
---- Public License as published by the Free Software Foundation; ----
---- either version 2.1 of the License, or (at your option) any ----
---- later version. ----
---- This source is distributed in the hope that it will be ----
---- useful, but WITHOUT ANY WARRANTY; without even the implied ----
---- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR ----
---- PURPOSE. See the GNU Lesser General Public License for more ----
---- details. ----
---- You should have received a copy of the GNU Lesser General ----
---- Public License along with this source; if not, download it ----
---- from http://www.opencores.org/lgpl.shtml ----
library ieee;
use ieee.std_logic_1164.all;
entity v_sr is
port( clk,clrn: in std_logic;
sren,tosr : in std_logic_vector(6 downto 0);
srsel : in integer range 0 to 7;
clr_i,set_i,bset,bclr : in std_logic;
rd_sreg, wr_sreg : in std_logic;
c : inout std_logic_vector(7 downto 0);
sr : inout std_logic_vector(7 downto 0)
end v_sr;
architecture sr of v_sr is
begin
c <= sr when rd_sreg = '1' else
"ZZZZZZZZ";
process(clk,clrn,rd_sreg,sr)
begin
if clrn = '0' then
sr <= "00000000";
elsif clk'event and clk = '1' then
if wr_sreg = '1' then
sr <= c;
elsif bset = '1' or bclr = '1' then
sr(srsel) <= bset;
elsif clr_i = '1' or set_i = '1' then
sr(7) <= set_i;
else
for i in 0 to 6 loop
if sren(i) = '1' then
sr(i) <= tosr(i);
end if;
end loop;
end if;
end if;
end process;
end sr;
