范例:opencore组织RISCMCU IP Core全套最新代码 _ram | ----------------------------------------------------------------------------
---- WISHBONE RISCMCU IP Core ----
---- This file is part of the RISCMCU project ----
---- http://www.opencores.org/projects/riscmcu/ ----
---- Description ----
---- Implementation of a RISC Microcontroller based on Atmel AVR ----
---- AT90S1200 instruction set and features with Altera Flex10k20 FPGA. ----
---- Author(s): ----
---- - Yap Zi He, yapzihe@hotmail.com ----
---- Copyright (C) 2001 Authors and OPENCORES.ORG ----
---- This source file may be used and distributed without ----
---- restriction provided that this copyright statement is not ----
---- removed from the file and that any derivative work contains ----
---- the original copyright notice and the associated disclaimer. ----
---- This source file is free software; you can redistribute it ----
---- and/or modify it under the terms of the GNU Lesser General ----
---- Public License as published by the Free Software Foundation; ----
---- either version 2.1 of the License, or (at your option) any ----
---- later version. ----
---- This source is distributed in the hope that it will be ----
---- useful, but WITHOUT ANY WARRANTY; without even the implied ----
---- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR ----
---- PURPOSE. See the GNU Lesser General Public License for more ----
---- details. ----
---- You should have received a copy of the GNU Lesser General ----
---- Public License along with this source; if not, download it ----
---- from http://www.opencores.org/lgpl.shtml ----
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity v_ram is
port( addrbus : in std_logic_vector(7 downto 0);
rd_ram, wr_ram, ld_mar, ld_mbr : in std_logic;
clk, clrn : in std_logic;
c : inout std_logic_vector(7 downto 0)
end entity;
architecture ram of v_ram is
component lpm_ram_dq
generic( lpm_width: positive := 8;
lpm_widthad: positive := 8;
lpm_numwords: natural := 256;
lpm_file: string := "ram.mif";
lpm_indata: string := "unregistered";
lpm_address_control: string := "unregistered";
lpm_outdata: string := "unregistered"
port( data: in std_logic_vector(lpm_width-1 downto 0);
address: in std_logic_vector(lpm_widthad-1 downto 0);
we: in std_logic;
inclock: in std_logic := '0';
outclock: in std_logic := '0';
q: out std_logic_vector(lpm_width-1 downto 0)
end component;
signal mar, mbr, ram_out : std_logic_vector(7 downto 0);
begin
sram: lpm_ram_dq
port map(data => mbr, address => mar, we => wr_ram, q => ram_out);
c <= ram_out when rd_ram = '1' else
"ZZZZZZZZ";
process(clk,clrn)
begin
if clrn = '0' then
mar <= "00000000";
mbr <= "00000000";
elsif clk'event and clk = '1' then
if ld_mbr = '1' then
mbr <= c;
end if;
if ld_mar = '1' then
mar <= addrbus;
end if;
end if;
end process;
end ram;
