[matlab]
范例:opencore组织RISCMCU IP Core全套最新代码 _port_bit
2099|0
sherry88|  楼主 | 2010-8-30 11:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
---- WISHBONE RISCMCU IP Core       ----
---- This file is part of the RISCMCU project     ----
---- http://www.opencores.org/projects/riscmcu/    ----
---- Description        ----
---- Implementation of a RISC Microcontroller based on Atmel AVR ----
---- AT90S1200 instruction set and features with Altera Flex10k20 FPGA. ----
---- Author(s):        ----
----  - Yap Zi He, yapzihe@hotmail.com     ----
---- Copyright (C) 2001 Authors and OPENCORES.ORG    ----
---- This source file may be used and distributed without   ----
---- restriction provided that this copyright statement is not   ----
---- removed from the file and that any derivative work contains  ----
---- the original copyright notice and the associated disclaimer.  ----
---- This source file is free software; you can redistribute it  ----
---- and/or modify it under the terms of the GNU Lesser General  ----
---- Public License as published by the Free Software Foundation;  ----
---- either version 2.1 of the License, or (at your option) any  ----
---- later version.        ----
---- This source is distributed in the hope that it will be   ----
---- useful, but WITHOUT ANY WARRANTY; without even the implied  ----
---- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR   ----
---- PURPOSE. See the GNU Lesser General Public License for more  ----
---- details.         ----
---- You should have received a copy of the GNU Lesser General   ----
---- Public License along with this source; if not, download it  ----
---- from http://www.opencores.org/lgpl.shtml     ----
library ieee;
use ieee.std_logic_1164.all;
entity v_port_bit is
port( rd_port,wr_port,rd_ddr,wr_ddr,rd_pin : in std_logic;
  clk,clrn : in std_logic;
  c : inout std_logic;
  pin : inout std_logic
end v_port_bit;
architecture port_bit of v_port_bit is
signal datareg, ddr : std_logic;
begin
c <= datareg when rd_port = '1' else
  ddr when rd_ddr = '1' else
  pin when rd_pin = '1' else
  'Z';
pin <=  datareg when ddr = '1' else
  'Z';
process(clrn, clk)
begin
if clrn = '0' then
  datareg <= '0';
  ddr <= '0';
elsif clk'event and clk = '1' then
  if wr_port = '1' then
   datareg <= c;
  end if;
  if wr_ddr = '1' then
   ddr <= c;
  end if;
end if;
end process;
end port_bit;
