[产品供应] 235870-001 70-40818-01 EVA3000 EVA5000控制器电池1000保一年
2345|2
 楼主| iris162 发表于 2010-9-1 09:43 | 显示全部楼层 |阅读模式
70-40818-01 235870-001  Battery pack - 2V, 15AH -
HSV100 Controller  Enterprise Virtual Array 3000 (EVA3000)
HSV110 Controller Enterprise Virtual Array 5000 (EVA5000)
北京中盛广信息技术有限公司 主营HP IBM 小型机存储 整机 维保备件 RX2600 RX2620 RX4640 RP2470 RP3410 RP3440 RP4440 RP7420 EVA3000 EVA5000 HSV110
HSV100控制器及整套备件 VA7100 VA7400 整机备件 A500 L2000 C3000 C8000 B180L ALPHASERVER DS10 DS10L DS20E ES40 IBM P630
EMC CX200 CX300 CX500 CX700 SPS 1000W 后备电池
Alphaserver1200 都是现货供应,欢迎来电询价及洽谈业务。联系电话010-88124915/15010161355 QQ:1390767849
RP4440 RX4640 备件支持列表
PCA, Processor Extender A6961-60007 A6961-67007 A6961-69007
PCA, Processor Extender - (RoHS) A6961-60207 A6961-67207 A6961-69207
PCA, I/O baseboard (includes VRMs) A6961-60201 A6961-67401 A6961-69401
PCA, I/O baseboard (includes VRMs) - (RoHS) A6961-60401 A6961-67501 A6961-69501
PCA, I/O baseboard (includes VRMs) - (RoHS - dual core
processors only)
A6961-60401 A6961-67411 A6961-69511
PCA, 16 slot Memory Board A6961-60204 A6961-67204 A6961-69204
PCA, 16 slot Memory Board - (RoHS) A6961-60804 A6961-67804 A6961-69804
PCA, 32 slot Memory Board A7124-04006 A9739-67007 A9739-69007
PCA, 32 slot Memory Board - (RoHS) A7124-04008 A9739-67008 A9739-69008
PCA, Midplane Riser Board (Apian) A6961-60005 A6961-67005 n/a
PCA, Midplane Riser Board (Apian) - (RoHS) A6961-60105 A6961-67105 A6961-69105
PCA, SCSI Backplane/Management Assy, includes
Simplex board
A6961-04075 A6961-67024 n/a
Simplex board - (RoHS)
A6961-04076 A6961-67025 n/a
PCA, SCSI Duplex Board (HP-UX) A6961-60106 A6961-67106 n/a
PCA, SCSI Duplex Board (HP-UX) - (RoHS) A6961-60206 A6961-67206 n/a
PCA, Front Panel Display A6961-60008 A6961-67008 n/a
PCA, Front Panel Display - (RoHS) A6961-60108 A6961-67108 n/a
PCA, QuickFind Diagnostic Board (includes plastic cover
and label)
A6961-60009 A6961-67009 n/a
and label) - (RoHS)
A6961-60109 A6961-67109 n/a
PCA, Power Distribution Board A6961-60015 A6961-67015 n/a
PCA, Power Distribution Board - (RoHS) A6961-60115 A6961-67115 n/a
PCA, I/O Board to DVD connectivity (IDE/USB) A6961-60113 A6961-67113 n/a
PCA, I/O Board to DVD connectivity (IDE/USB) - (RoHS) A6961-60213 A6961-67213 n/a
Memory
256 MB DIMM A6967AX A6967AX n/a
512 MB DIMM A6968AX A6968AX n/a
1 GB DIMM A6969AX A6969AX A6969-69001
2 GB DIMM A6970AX A6970AX A6835-69001
4 GB DIMM AB475AX AD041A AB475-69001
Internal disks/removable media
36 GB 15K RPM SCSI Disk (A6981A) AB420-2101A AB420-2101A AB420-69001
73 GB 15K RPM SCSI Disk (A6983A) AB421-2101A AB421-2101A AB421-69001
146 GB 10K RPM SCSI Disk (A6984A) AB422-2101A AB422-2101A AB422-69001
300 GB 10K RPM SCSI Disk (A6984A) AB423-2101A AB423-2101A AB423-69001
DVD-R/CD-R Drive A7163-2100A A7163-67002 n/a
DVD-R/CD-RW Drive AB349-2100A AB349-67101 n/a
Fans
I/O Fan A6961-04055 A6961-04055 n/a
Power Supply Fan A6961-04028 A6961-04028 n/a
Processors
Montecito CPU Assembly (1.6 GHz), 18 Mb cache AD139AX AD139A-67001 AD139-69001
Montecito CPU Assembly (1.6 GHz), 24 Mb cache AD268AX AD268A-67001 AD268-69001
Cable
Cable, Internal SCSI A6961-63006 A6961-63006 n/a
Cable, QuickFind Diagnostic to Midplane A6961-63005 A6961-63005 n/a
Cable, Power Distribution to Midplane Ribbon A6961-63004 A6961-63004 n/a
Cable, Power Distribution to Midplane 10 pin A6961-63003 A6961-63003 n/a
Cable, SCSI Controller Jumper (Simplex only) A6961-63011 A6961-63011 n/a
Cable, SCSI Backplane to Midplane A6961-63008 A6961-63008 n/a
Cable, Display to IDE to Midplane A6961-63002 A6961-63002 n/a
Power Cord - S. Africa 8120-5341 n/a
Power Cord - HK & UK & Singapore 8120-1351 n/a
Power Cord - Australia 8120-1369 n/a
Power Cord - Europe 8120-1689 n/a
Power Cord - Swiss 8120-2104 n/a
Power Cord - Denmark 8120-6814 n/a
Power Cord - N. Amer 250 V / Japan 8121-0875 n/a
Power Cord - Israel 8120-6800 n/a
Power Cord - Argentina 8120-8390 n/a
Power Cord - Chile 8120-8389 n/a
Power Cord - China 8120-8376 n/a
Power Cord - S. America 8121-0668 n/a
Power Cord 8120-1351 8120-1351
C13/C14 Jumper cord 8120-6514 n/a
Miscellaneous
Power Supply 0950-4428 A6961-67125 n/a
PCI Card OL* Divider (doorbell and latch included) A6961-04047 A6961-67020 n/a
PCI Retention Clip A6961-40021 A6961-67021 n/a
Server battery 1420-0386 BR2330 n/a
Filler, Memory, Air Blocker A6961-40034 A6961-40034 n/a
Rack solutions
Rack Mount Hardware, Right (included with Left Bracketin kit)
5069-3305 A6977-67001 n/a
Rack Mount Hardware, Left (included with Right Bracketin kit)
5069-3306 A6977-67002 n/a
Bezel-Rack Mount A6961-04043 A6977-67022 n/a
Rackless Kit A6961-04001 n/a n/a
Core I/O Cards
U320 Dual Port SCSI Core I/O A6961-60011 A6961-67011 n/a
Dual Port GigE LAN Card AB352-60001 AB352-67001 n/a
PCI-X RAID Smart Array 6402 U320, 2ch 322391-001 309520-001N 309520-001
SPS-BD, Mem, 128, 72Bt, DDR, W.Bty (mounted on PCA
for Prod # A9890A)
322391-001 309521-001N 309521-001
北京中盛广信息技术有限公司
主营HP IBM 小型机存 整机 RX2600 RX2620 RX4640 RP2470 RP3410 RP3440 RP4440 RP7420 EVA3000 EVA5000 HSV110
HSV100
后备电池
Alphaserver1200
 楼主| iris162 发表于 2010-10-22 10:11 | 显示全部楼层
HP  RP2470     配置:
A6890A        HP9000 RP2470 SERVER
A6889-60001   HP9000 Server RP2430 RP2470 System Board
A6891A     HP9000 650MHz PA-RISC 8700 processor with 1.5MB cache  A5841A         HP9000 A5841-60001 512MB DIMM MEMORY 1/2 OF A5841A FOR 9000
A6948A         HP9000 A6948-69001 36.4GB 15K ULTRA 320 HOT PLUG SCSI DISK
A6889-60002  HP9000 GSP BOARD for RP2405 RP24XX 9000 Series A5570-69009      HP9000 POWER SUPPLY FOR A400/A500/RP24xx SERVERS
HP9000 RP3440   配置:
        A7137A        HP9000 RP3440
        AB354A        PA8800 1.0GHZ CPU 双核
        A6967A        PC2100 DDR(256MB*8)=2GB
        A7285A        73GB 10K U320
        A7231-66580        MP卡
        0950-4621        电源
HP RX2600        配置:1.5MHZ CPU*2 /4G内存/73G硬盘/成色好
compaq ALPHASERVER DS10 配置:
配置一:466MHZCPU、512MB内存、1000M网卡、PBXGK-BB显卡。状态正常,无硬盘
配置二:466MHZCPU、256MB内存、1000M网卡、PBXGK-BB显卡。状态正常,无硬盘
配置三:466MHZCPU、256MB内存、1000M网卡。无显卡,无硬盘,系统状态正常
配置四:466MHZCPU 54-30074-01主板、无电源、无硬盘、无内存、状态正常
配置五:54-30074-01主板、388210-001硬盘、PBXGX-BB显卡、TLZ10磁带机。状态正常,无电源,无内存
配置六:54-30074-01主板、1000M网卡,无内存、无电源、无硬盘
配置七:600MHZCPU 54-30074-12主板、无电源、无硬盘、无内存、状态正常
配置八:600MHZCPU、54-30074-12主板、54-24941-HA内存*2、30-50454-03电源、323235-001硬盘、3X-DEPVZ-AA显卡,状态正常
compaq ALPHASERVER  DS20E 配置:
配置一: 54-24756-03主板、54-24758-35CPU、20-01DSA-08内存、KZPCM-DX(SCSI卡)、30-50662-01电源。状态正常,缺少盘笼地址线
配置二: 54-24756-03主板、54-24758-35CPU、20-01DSA-08内存、KZPCM-DX(SCSI卡)、DNBE1-AB七号信令卡、DE504-BA网卡、30-50662-01电源。状态正常,无硬盘笼子,供电模板FAN1坏的
配置三: 54-24756-03主板、54-24758-35CPU、20-01DSA-08内存、30-50662-01电源。状态正常,缺少硬盘模块
P630       1.45GHz 1-Way *2/8GB/73G/DVD/显卡/SCSI卡/磁带机/光纤卡
P630        1.0GHz 1-Way /2GB/73G/DVD
P630        1.0GHz 1-Way /2GB/36G/DVD/
