[经验分享] 关于IAP
3624|3
 楼主| hyocean 发表于 2010-9-4 15:25 | 显示全部楼层 |阅读模式
各位,正在学习笙泉的单片机,我拿了例程中的程序,一块擦除的82E54(保证里面都是FF)烧写好芯片之后,运行一次,为什么用U2烧录器读出来的0X03400(起始IAP地址)还是FF?也就是说没写进去呢?
因为在我的程序里不能写不能读,没办法做这个实验,想用U2来读看一下,可读出来的还是FF,问题出在哪呢?
typedef struct IAP_Addr
{  unsigned char Low ;
   unsigned char High ;
#define     AP_End_Addr       0x033FF
#define     IAP_Start_Addr    0x03400
#define     IAP_End_Addr      0x037FF
#define     Xtal_Freq         0x24              // Unit:MHz-------------24M晶振
#include    "REG_MPC82L54.H"
void IAP_Write_512B (void) ;
void IAP_Write_Byte(unsigned int, unsigned char,unsigned char) ;
void IAP_Fail(void);
unsigned char Trigger_Check1=0x55;
void main(void)
{  P37=1;
   IAP_Write_512B() ;
   P37=0;//程序执行一次亮红灯,按理来说已经写好IAP才对,但0X03400里面的内容 还是FF,不明白怎么回事
while (1) {}
{  unsigned int IAP_Addr=IAP_Start_Addr;
   unsigned int IAP_Addr_Up_Bundary=IAP_Start_Addr+0x0200 ;
   for(;IAP_Addr<IAP_Addr_Up_Bundary;IAP_Addr++)
      IAP_Write_Byte(IAP_Addr,5,0xAA) ;
void IAP_Write_Byte(unsigned int IAP_Addr, unsigned char Value,unsigned char Trigger_Check2)
   ISPCR = ISPCR | 0x81 ;
   IFADRH = IAP_Addr >> 8;                      //IAP Flash Address High Byte
   IFADRL = IAP_Addr & 0xFF;                    //IAP Flash Address Low Byte
   IFD = Value ;                                //Flash data buffer
   IFMT = 0x02 ;                                //IAP Flash Mode Table (Write Mode)
   if (Trigger_Check1==0x55)
      SCMD = 0x46 ;
   else
      IAP_Fail() ;
   if (Trigger_Check2==0xAA)
   {  SCMD = 0xB9 ;
   else
   {  SCMD = 0x00 ;
      IAP_Fail() ;
   Trigger_Check2=0x00;
   ISPCR = ISPCR & 0x7F ;
//    IAP_Fail()
void IAP_Fail(void)
{  P24=0 ;//出错的话亮指示灯
   while(1) ;
 楼主| hyocean 发表于 2010-9-4 16:33 | 显示全部楼层
一个失误,原来是ISP空间里面选择了NONE……
David_ming 发表于 2010-9-5 01:19 | 显示全部楼层
liangzhi213 发表于 2013-11-30 14:45 | 显示全部楼层
没有明白?
