内部EEPROM,怎么不能实现存储呢??? 哪位给看问题呢?
2339|2
azeale123|  楼主 | 2010-9-6 18:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<intrins.h>
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
#define RdCommand 0x01//定义ISP的操作命令
#define PrgCommand 0x02
#define EraseCommand 0x03
#define Error 1
#define Ok 0
#define WaitTime 0x01
sfr ISP_DATA=0xe2;
sfr ISP_ADDRH=0xe3;
sfr ISP_ADDRL=0xe4;
sfr ISP_CMD=0xe5;
sfr ISP_TRIG=0xe6;
sfr ISP_CONTR=0xe7;
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar num;
void delayms(uint xms)
uint i,j;
for(i=xms;i>0;i--)        //i=xms即延时约xms毫秒
  for(j=110;j>0;j--);
void display(uchar shi,uchar ge)
        dula=1;
  P0=table[shi];
  dula=0;
  P0=0xff;
  wela=1;
  P0=0xfe;
  wela=0;
  delayms(5);
  dula=1;
  P0=table[ge];
  dula=0;
  P0=0xff;
  wela=1;
  P0=0xfd;
  wela=0;
  delayms(5);
/****************打开ISP,IAP************************/
void ISP_IAP_enable(void)
EA=0;//关总中断
ISP_CONTR=ISP_CONTR&0x18;/*0001 1000*/
ISP_CONTR=ISP_CONTR|WaitTime;/*写入硬件延时*/
ISP_CONTR=ISP_CONTR|0x80;/*ISPEN=1*/
/************关闭ISP,IAP**************************/
void ISP_IAP_disable(void)
ISP_CONTR=ISP_CONTR&0x7f;
ISP_TRIG=0x00;
EA=1;
/*****************公用的出发代码*****************/
void ISPgoon(void)
ISP_IAP_enable();
ISP_TRIG=0x46;
ISP_TRIG=0xb9;
_nop_();
/******************字节读********************/
unsigned char byte_read(unsigned int byte_addr)
ISP_ADDRH=(unsigned char)(byte_addr>>8);
ISP_ADDRL=(unsigned char)(byte_addr&0x00ff);
ISP_CMD=ISP_CMD&0xf8;
ISP_CMD=ISP_CMD|RdCommand;
ISPgoon();
ISP_IAP_disable();
return(ISP_DATA);
/**************扇区擦写************************/
void SectorErase(unsigned int sector_addr)
unsigned int iSectorAddr;
iSectorAddr=(sector_addr&0xfe00);
ISP_ADDRH=(unsigned char)(iSectorAddr>>8);
ISP_ADDRL=0x00;
ISP_CMD=ISP_CMD|EraseCommand;
ISPgoon();
ISP_IAP_disable();
/*************字节写*************************/
void byte_write(unsigned int byte_addr,unsigned char original_data)
ISP_CMD=ISP_CMD|PrgCommand;
ISP_DATA=original_data;
ISPgoon();
ISP_IAP_disable();
void main()
uchar a,b,num1;
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
num1=byte_read(0x2000);
if(num1>=60)
num1=0;
a=0;
b=0;
while(1)
  if(num>=20)
   num=0;
   num1++;
   SectorErase(0x2000);
   byte_write(0x2000,num1);
   if(num1==60)
    num1=0;
   a=num1/10;
   b=num1%10;
  display(a,b);
void timer0() interrupt 1
num++;
NE5532| | 2010-9-6 19:27 | 只看该作者
神啊,你用的哪种单片机啊?
azeale123|  楼主 | 2010-9-6 20:00 | 只看该作者
2# NE5532
STC89C55单片机
