上电依然有3ma的高电流存在
2638|15
 楼主| chenho 发表于 2010-9-8 10:57 | 显示全部楼层 |阅读模式
提示修改了设置,但上电依然有3ma的高电流存在,会不会与rem有关,还是其他原因,您们有没有这种芯片的测试数据?
happy_10 发表于 2010-9-8 11:07 | 显示全部楼层
你再详细一点说明一下
 楼主| chenho 发表于 2010-9-8 13:15 | 显示全部楼层
单时钟工作76.8khz,3v工作电压,未使用rem,porte设置为输出低电平,其余端口作为输入输出,输入均有上拉,问题是上电开机瞬时电流3ma(持续200ms多),该电流与其他单片机相比太大了!
我想了解一下有没有这方面的参考数据,还是我对rem或其他方面的设置有问题?
happy_10 发表于 2010-9-8 13:30 | 显示全部楼层
76.8KHZ?是不是32.768KHZ?
把程序上传上来看看吧
 楼主| chenho 发表于 2010-9-8 15:06 | 显示全部楼层
晶体频率是76.8khz
RESET:
;    set special register and initialize
        NOP
        NOP
        LDI        SPR,00H                ;NO PULL UP
        LDI        PLCD,00H        ;LCD 1/4DUTY 1/3BIAS AND USE AS PORTC,D
        LDI        PACR,1100B        ;0:BUSY;1:SDA;2:RQS;3:SCK
        LDI        PBCR,0000B        ;0:0/ON/OFF;1:MM/INCH;2:-;3:-
        LDI        PCCR,1000B        ;3OWER CONTROL
        LDI        PDCR,1100B        ;0pt;1VP/CLR;2:WAIT;3:WORK
        LDI        PECR,0000B
        LDI        PORTE,0011B
        LDI        PORTC,1111B
        LDI        PORTB,1111B        B.3
        LDI        PORTA,0000B
        LDI        PORTD,1011B        A,PC,PD disable inter pull-up
        LDI        TEMP1,0FH        ;DELAY
        SBIM        TEMP1,01H        ;
        BNZ        $-1                ;
        LDI        PORTD,0011B        ;CLOSE
        LDI        TM0,02H
Clear_RAM:                       ;CLEAR RAM
        LDI        DPH,01H
        LDI        DPM,02H
        LDI        DPL,0FH
CR_LOOP:
        LDI        INX,00H
        SBIM        DPL,01H
        BNZ        CR_LOOP
        SBIM        DPM,01H
        SBI        DPM,07H
        BNZ        CR_LOOP
Clear_RAM1:                       ;CLEAR RAM
        LDI        DPH,00H
        LDI        DPM,07H
        LDI        DPL,0FH
CR_LOOP1:
        LDI        INX,00H
        SBIM        DPL,01H
        BNZ        CR_LOOP1
        SBIM        DPM,01H
        SBI        DPM,0010B
        BC        CR_LOOP1
        LDI        070H,00H
Clear_segments:
        LDI        TEMP1,00H
        STA        SEG1
        STA        SEG2
        STA        SEG3
        STA        SEG4
        STA        SEG5
        STA        SEG6
        STA        SEG7
        STA        SEG8
        STA        SEG9
        STA        SEG10
        STA        SEG11
        STA        SEG12
        STA        SEG13
        ldi        MODE,00H
        LDI        PORTB,0FH        ;
        LDA        PORTB,00H
        STA        STA_PB,00H
        BA1        $+2
        LDI        STAT0,01H        ;NO AUTO OFF
        LDA        STA_PB,00H
        BA0        $+3
        ORIM        MODE,08H
        ORIM        STAT3,01H        ;FLASH WHILE HALF SLEEPING
        LDI        STA_PD,1011B        ;ON
        STA        PORTD,00H
        LDA        PORTD,00H
        BA0        $+3
        ORIM        MODE,08H
        ORIM        STAT2,02H        ;OPT FOR DISPLAY
        ORIM        STAT2,08H        ;DIRECTION SELECT
        ORIM        STAT0,04H        ;zero
        LDI        STA_CS,05H
        LDI        TMP0,00H
        LDI        TMP1,00H
BUSY_LOW:
        LDI        PORTA,03H
        LDA        PORTA,00H
        BA0        BUSY_HIGH        ;BUSY HIGH
        ADIM        TMP0,01H
        BNC        BUSY_LOW
        ADIM        TMP1,01H
        BNC        BUSY_LOW
        ORIM        ERR,04H                ;NO BUSY
        JMP        LCD_ON
BUSY_HIGH:
        LDI        IRQ,00H
        LDI        PORTA,07H        ;RQS HIGH
        STA        ACC_BUF,00H        ;DELAY
        LDI        TEMP1,0FH        ;
        SBIM        TEMP1,01H        ;
        BNZ        $-1                ;
        LDI        PORTA,03H        ;RQS HIGH
        LDI        PARM,02H        ;DELAY        ABOUT 200MS
        CALL        Delay
LCD_ON:
        LDI        LCDON,4                ;LCD ON
;    main program
MAIN:
        JMP        MAIN
END
happy_10 发表于 2010-9-8 15:21 | 显示全部楼层
你输入的口并没有打开上拉电阻
happy_10 发表于 2010-9-8 15:22 | 显示全部楼层
正确打开上拉电阻的方法:
1.设置I/O口方向寄存器为输入口.
2.将系统寄存器13的最高位置1
3.将I/O口数据寄存器写1
 楼主| chenho 发表于 2010-9-8 15:38 | 显示全部楼层
我通过外接vdd或外接电阻至vdd方式,没使用内部上拉
happy_10 发表于 2010-9-8 15:48 | 显示全部楼层
建议你先把设置为输入口的外接的VDD,或是电阻到VDD断开,在程序中打开内置的上拉电阻,并将主程序只写成
NOP
HALT
NOP
NOP
试一下.
另外,是用EVB仿真还是烧好芯片进行的测试?
 楼主| chenho 发表于 2010-9-8 16:12 | 显示全部楼层
我测试了一下,200ms的时间大概就是初始化的时间,再试吧!
通过烧好的芯片进行的测试,evb仿真时也试了,但没发现这么大的电流。
happy_10 发表于 2010-9-8 16:33 | 显示全部楼层
其实规格要求使用32.768K晶振,你使用的76.8K晶振,属超规格要求使用,不建议这样使用
tian111 发表于 2010-9-17 11:00 | 显示全部楼层
碰到了差不多的问题
