请教DSP错误类型
3027|0
 楼主| keaiduoyu 发表于 2010-9-15 19:48 | 显示全部楼层 |阅读模式
自己做了一块5402的开发板,但是仿真器在LOAD  .OUT文件时会出现如下错误类型:
Trouble Writing Register:
Error 0x80001024/-1058
Fatal Error during: Register, Execution, Target,
Device driver: Emulator Controller not responding
It is recommended to RESET EMULATOR.  This will disconnect each
target from the emulator.  The targets should then be power cycled
or hard reset followed by an emureset and reconnect to each target.
之前的开发板是好的,硬件上已经检查过,信号都一样,各位高手,请教有谁有碰到过类似的问题吗??现在卡在这里了没法进行下步实验,谢谢
