WinCE6.0编译时出现以下错误
4663|2
pxy94|  楼主 | 2010-10-9 17:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
WinCE6.0编译时出现以下错误,它说CloseGestureInfoHandle,GetGestureInfo等函数没有定义,我查到这几个函数都在TileWindow.cpp这个文件里面,路径为D:\WINCE600\PUBLIC\IE\OAK\IESAMPLE_EXR\CORE,但这个文件是它自带的,怎么会出现没定义的情况呢,真是搞不明白,有知道的大虾指点一下。
commctrl.lib(prsht.obj) : error LNK2019: unresolved external symbol CloseGestureInfoHandle referenced in function "int __cdecl PropSheetDlgProc(struct HWND__ *,unsigned int,unsigned int,long)" ([email=?PropSheetDlgProc@@YAHPAUHWND__@@IIJ@Z]?PropSheetDlgProc@@YAHPAUHWND__@@IIJ@Z[/email])
commctrl.lib(tab.obj) : error LNK2001: unresolved external symbol CloseGestureInfoHandle
commctrl.lib(tab.obj) : error LNK2019: unresolved external symbol GetGestureInfo referenced in function Tab_WndProc
commctrl_hpc.lib(lvlogic.obj) : error LNK2019: unresolved external symbol SetWindowAutoGesture referenced in function "void __cdecl ListView_UpdateAutoGestures(struct _LV *)" ([email=?ListView_UpdateAutoGestures@@YAXPAU_LV@@@Z]?ListView_UpdateAutoGestures@@YAXPAU_LV@@@Z[/email])
commctrl_hpc.lib(treeview_hpc.obj) : error LNK2001: unresolved external symbol SetWindowAutoGesture
commctrl_hpc.lib(lvlogic.obj) : error LNK2019: unresolved external symbol GetWindowAutoGesture referenced in function "void __cdecl ListView_UpdateAutoGestures(struct _LV *)" ([email=?ListView_UpdateAutoGestures@@YAXPAU_LV@@@Z]?ListView_UpdateAutoGestures@@YAXPAU_LV@@@Z[/email])
commctrl_hpc.lib(treeview_hpc.obj) : error LNK2019: unresolved external symbol GetAnimateMessageInfo referenced in function "int __cdecl TV_PlatformPreproc(struct HWND__ *,unsigned int,unsigned int,long,struct _TREE *)" ([email=?TV_PlatformPreproc@@YAHPAUHWND__@@IIJPAU_TREE@@@Z]?TV_PlatformPreproc@@YAHPAUHWND__@@IIJPAU_TREE@@@Z[/email])
commctrl.lib(lvgesture.obj) : error LNK2001: unresolved external symbol GetAnimateMessageInfo
commctrl.lib(lvgesture.obj) : error LNK2019: unresolved external symbol "public: static void __cdecl TouchPerf::ReleaseSession(void)" ([email=?ReleaseSession@TouchPerf@@SAXXZ]?ReleaseSession@TouchPerf@@SAXXZ[/email]) referenced in function "public: __cdecl GestureTriggeredScrollCtrl::~GestureTriggeredScrollCtrl(void)" ([email=??1GestureTriggeredScrollCtrl@@QAA@XZ]??1GestureTriggeredScrollCtrl@@QAA@XZ[/email])
commctrl.lib(lvgesture.obj) : error LNK2019: unresolved external symbol "public: static void __cdecl TouchPerf::AcquireSession(void)" ([email=?AcquireSession@TouchPerf@@SAXXZ]?AcquireSession@TouchPerf@@SAXXZ[/email]) referenced in function "public: __cdecl GestureTriggeredScrollCtrl::GestureTriggeredScrollCtrl(void)" ([email=??0GestureTriggeredScrollCtrl@@QAA@XZ]??0GestureTriggeredScrollCtrl@@QAA@XZ[/email])
E:\PanXiaoya\eSOM9261CDROM\WINCE6.0\Project\OSDesignsAT91\EEIC08Full\Wince600\EEIC08_ARMV4I\cesysgen\oak\target\ARMV4I\retail\commctrl.dll : fatal error LNK1120: 7 unresolved externals
NMAKE : fatal error U1077: 'link' : return code '0x460'
Stop.
NMAKE : fatal error U1077: 'D:\WINCE600\sdk\bin\i386\nmake.exe' : return code '0x2'
Stop.
gooogleman| | 2010-10-15 12:35 | 只看该作者
有可能是安装不好,
build and sysgen 一遍。
pxy94|  楼主 | 2010-10-18 17:23 | 只看该作者
有可能是安装不好,
gooogleman 发表于 2010-10-15 12:35
多谢,确实是这个原因,补丁顺序搞错了
