DSP如果用内部振荡器,X1引脚是否可以输出时钟?
2236|1
 楼主| congfeiyu 发表于 2010-10-14 11:13 | 显示全部楼层 |阅读模式
如果用内部振荡器,就在X1、X2/CLKIN引脚间跨接晶体,5416DSP的datasheet上说XI引脚是“Output pin from the internal oscillator for the crystal. If the internal oscillator is not used, X1 should be left unconnected. X1 does not go into the high-impedance state when OFF is low.”那X1是否可以输出内部振荡器的时钟?谢谢!
 楼主| congfeiyu 发表于 2010-10-15 08:53 | 显示全部楼层
不能 驱动不了
