ltc6802-2
3930|3
 楼主| yinchuanfeng 发表于 2010-10-26 16:49 | 显示全部楼层 |阅读模式
哪位大虾知道ltc6802-2芯片的寄存器怎么配置啊
 楼主| yinchuanfeng 发表于 2010-10-26 17:12 | 显示全部楼层
#include <hidef.h> /* for EnableInterrupts macro */
#include "derivative.h" /* include peripheral declarations */
//#define  STCVAD    0X1E    /*启动电压A/D采集自检,所有CV=0X555*/
//#define  STTMPAD   0X3F    /*启动温度A/D采集自检,所有TMP=0xAAA*/
//#define  RDTMP     0X08    /*读取温度命令*/
//#define  RDCV      0X04    /*读取电压命令
//配置寄存器组定义
//#define CFGR0 0x03         /*设定测量电压周期,UV/OV比较周期*/
//#define CFGR1 0x00         /*turn off shorting switch for cell x */
//#define CFGR2 0x00
//#define CFGR3 0x00
//#define CFGR4 0x5e         /*设定UV*/
//#define CFGR5 0x98         /*设定OV*/
#define SCK    PTBD_PTBD1
#define MOSI   PTCD_PTCD1
#define MISO   PTAD_PTAD0
#define CSBI   PTCD_PTCD2
#define WRCFG 0x01
#define RDCFG 0x02
#define RDCV 0x04
#define RD** 0x06
#define STCVAD 0X1E
//#define  STCVAD_USE 1
unsigned char DataBuffer;
unsigned char CVR[19];
unsigned char wrcfg[6]={0x0,0x00,0x00,0x00,0x5e,0x98};
void IO_init()
   PTBDD_PTBDD1=1;
   PTCDD_PTCDD2=1;//cs
   PTADD_PTADD0=0;
   PTCDD_PTCDD1=1;
   SCK = 0;
   MOSI = 0;
   CSBI = 1;
void Delay(unsigned char Value)
  for(;Value>0;Value--)
void SpiWrite(unsigned char data)
   unsigned char i;
   for(i=0;i<8;i++)
      Delay(10);
      SCK = 0;
      if(0x80&data)
        MOSI = 1;
      else
        MOSI = 0;
      Delay(10);
       SCK = 1;
      data<<=1;
void TLC6802_init()
  unsigned char i;
  CSBI = 0;
  SpiWrite(WRCFG);
  for(i=0;i<6;i++)
     SpiWrite(wrcfg[i]);
  CSBI = 1;
  Delay(10);
void SPIRead()
  unsigned char i;
  DataBuffer=0;
  for(i=0;i<8;i++)
     SCK = 0;
     Delay(9);
     SCK = 1;
     Delay(1);
     if(MISO)
       DataBuffer|=0x01;
     Delay(10);
     DataBuffer<<=1;
void main(void)
  unsigned char i;
  IO_init();
  TLC6802_init();
  Delay(3);
  EnableInterrupts;
  for(;;)
      CSBI = 0;
      SpiWrite(0x80);
      SpiWrite(RDCFG);
      SpiWrite(RDCV);
      //SpiWrite(STCVAD);
      Delay(30);
      for(i=0;i<7;i++)
        SPIRead();
        CVR[i]=DataBuffer;
        Delay(10);
      CSBI = 1;
      Delay(50);
   #ifdef STCVAD_USE
      CSBI = 1;
      Delay(10);
      CSBI = 0;
      SpiWrite(STCVAD);
      Delay(30);
      CSBI = 1;
   #endif
    __RESET_WATCHDOG();
可以通讯,但是得不到正确值,拜求大虾指导,感激不尽!!!!!!!!!!!!!!!!!!!!
Sarah2011 发表于 2011-7-13 15:55 | 显示全部楼层
是个老帖子了,不过楼主还在继续研究吗?现在凌特推出的LTC6803,希望和您交流一下
 楼主| yinchuanfeng 发表于 2012-12-3 09:51 | 显示全部楼层
呵呵这是多年前的帖子了
