[STM8] STM8S103 SPI Slave模式求救
995|3
 楼主| doykee 发表于 2017-8-25 18:59 | 显示全部楼层 |阅读模式
使用STM8S103作为SPI Slave设备,但是STM8中断里面收到的全是0x1,收不到正确的数据,STM8发送看起来是对的。求大神帮忙指点一下,下面是代码:
void spi_slave_init()
    //NSS
    GPIOA->DDR &= ~SPI_SSEL_PIN; //输入模式
    GPIOA->CR1 &= ~SPI_SSEL_PIN; //浮空输入
    GPIOA->ODR &= (uint8_t)~SPI_SSEL_PIN; //write low
    GPIOC->DDR |= SPI_MISO_PIN; //输出模式
    GPIOC->CR1 |= SPI_MISO_PIN; //推挽输出
    GPIOC->DDR &= ~SPI_MOSI_PIN; //输入模式
    GPIOC->CR1 &= ~SPI_MOSI_PIN; //浮空输入
    GPIOC->DDR &= ~SPI_CLK_PIN;  //输入模式
    GPIOC->CR1 &= ~SPI_CLK_PIN;  //浮空输入
        SPI_DeInit();
        // Initialize SPI in Slave mode, NSS hardwere management  */
        SPI_Init(SPI_FIRSTBIT_MSB, SPI_BAUDRATEPRESCALER_2, SPI_MODE_SLAVE, SPI_CLOCKPOLARITY_HIGH,
                SPI_CLOCKPHASE_2EDGE, SPI_DATADIRECTION_2LINES_FULLDUPLEX, SPI_NSS_SOFT,(uint8_t)0x07);
        SPI_ITConfig(SPI_IT_RXNE, ENABLE);// Receive buffer not empty interrupt Enable
        SPI_Cmd(ENABLE); // SPI enable
uint8_t spi_rw(uint8_t byte)
    char ch = 0;
    while (SPI_GetFlagStatus(SPI_FLAG_TXE) == RESET);
    SPI->DR = byte;
    while(SPI_GetFlagStatus(SPI_FLAG_RXNE) == RESET);
    ch = ((uint8_t)SPI->DR);
    return ch;
INTERRUPT_HANDLER(SPI_IRQHandler, 10)
  /* In order to detect unexpected events during development,
     it is recommended to set a breakpoint on the following instruction.
  uint8_t Rx_byte;
  Rx_byte = spi_rw(0x18);
  printf("%x ", Rx_byte);
中断里面收到的打印全是0x1,不知道什么原因啊,但是SPI Master可以收到stm8发送的0x18,
mmuuss586 发表于 2017-8-25 19:56 | 显示全部楼层
你这个函数干嘛呀?
先发送后接受,改成单独的发送或接受试下;
feelhyq 发表于 2017-8-25 23:32 | 显示全部楼层
戈卫东 发表于 2017-8-26 09:21 | 显示全部楼层
看起来这个spi_rw不适合在ISR里面用。
