S3C6410的tvscaler寄存器为何无法读写?
2731|1
 楼主| suseng777 发表于 2010-11-10 10:34 | 显示全部楼层 |阅读模式
看了海天雄开发板下tvscaler的驱动源码,ioremap后,base为映射后的虚拟地址,寄存器的物理地址0x76300000,base为0xC9400000,紧接着对tvscaler的寄存器无法读写
static int s3c_tvscaler_probe(struct platform_device *pdev)
        struct resource *res;
        int ret;
        /* find the IRQs */
        s3c_tvscaler_irq = platform_get_irq(pdev, 0);
        if(s3c_tvscaler_irq <= 0) {
                printk(KERN_ERR PFX "failed to get irq resouce\n");
              return -ENOENT;
        /* get the memory region for the tv scaler driver */
       res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
       if(res == NULL) {
               printk(KERN_ERR PFX "failed to get memory region resouce\n");
               return -ENOENT;
        s3c_tvscaler_mem = request_mem_region(res->start, res->end-res->start+1, pdev->name);
        if(s3c_tvscaler_mem == NULL) {
                printk(KERN_ERR PFX "failed to reserve memory region\n");
              return -ENOENT;
        base = ioremap(s3c_tvscaler_mem->start, s3c_tvscaler_mem->end - res->start + 1);
        printk("tvscaler : base, res->start, res->end:=%08x %08x %08x\n", base, res->start, res->end);
        printk("base-reg : 0x%08x\n", __raw_readl(base));    //先读出来映射的寄存器值全为0
        __raw_writel(0x00070B12, base);                   //写入0x00070B12到base映射的寄存器中
        printk("base-reg : 0x%08x\n", __raw_readl(base));    //再次读出,还是全为0
                printk(KERN_ERR PFX "failed ioremap\n");
                return -ENOENT;
        tvscaler_clock = clk_get(&pdev->dev, "tv_encoder");
        if(tvscaler_clock == NULL) {
                printk(KERN_ERR PFX "failed to find tvscaler clock source\n");
                return -ENOENT;
        clk_enable(tvscaler_clock);
        h_clk = clk_get(&pdev->dev, "hclk");
        if(h_clk == NULL) {
                printk(KERN_ERR PFX "failed to find h_clk clock source\n");
                return -ENOENT;
        init_waitqueue_head(&waitq);
        ret = request_irq(s3c_tvscaler_irq, s3c_tvscaler_isr, IRQF_DISABLED,
                        "TV_SCALER", NULL);
        if (ret) {
                printk("request_irq(TV_SCALER) failed.\n");
                return ret;
       return 0;
以下是板子开机启动的部分信息,寄存器的物理地址0x76300000,可以看到映射的虚拟地址是0xC9400000,不明白为何无法对映射后的tvscaler寄存器读写,
哪位高手能指点一下吗?
另外,tvencoder驱动部分是可以读写的,读出来的是默认值。
eth%d: con201 Invalid ethernet MAC address. using default config,  Please set using ifconfig
eth0: dm9000 at f7200300,f7200304 IRQ 111 MAC: 00:e0:4a:bc:15:e8
Linux video capture interface: v2.00
s3c-fimc: controller 0 registered successfully
s3c-fimc: controller 1 registered successfully
S3C6400 MFC Driver, (c) 2007 Samsung Electronics
S3C PostProcessor Driver v3.12, (c) 2009 Samsung Electronics
S3C6410 TV encoder Driver, (c) 2008 Samsung Electronics
tvencoder:base,res->start,res->end:=c9200000 76200000 762fffff
base-reg : 0x00010000
base-reg : 0x00010100
S3C6410 TV encoder Driver init OK.
S3C6410 TV scaler Driver, (c) 2008 Samsung Electronics
tvscaler : base, res->start, res->end:=c9400000 76300000 763fffff
base-reg : 0x00000000             //读出来全是0,base对应的寄存器MOD的初始值0x00070B12的
base-reg : 0x00000000             //尝试写入0x00070B12到base映射的寄存器再次读出还是为0
S3C6410 TV scaler Driver init OK.
S3C JPEG Driver, (c) 2007 Samsung Electronics
s3c_g2d_probe called
s3c_g2d_probe Success
S3C G2D Init : Done
S3C G3D Driver, (c) 2007-2009 Samsung Electronics
s3c_g3d version : 0x1050000
G3D_RESERVED_MEM_SIZE : 16 MB
G3D_CHUNK_SIZE : 2 MB
G3D_CHUNK_NUM : 8
0 th virt_addr = 0xc7800000, phy_addr = 0x57800000
1 th virt_addr = 0xc7a00000, phy_addr = 0x57a00000
2 th virt_addr = 0xc7c00000, phy_addr = 0x57c00000
3 th virt_addr = 0xc7e00000, phy_addr = 0x57e00000
4 th virt_addr = 0xc6000000, phy_addr = 0x56000000
5 th virt_addr = 0xc6200000, phy_addr = 0x56200000
6 th virt_addr = 0xc6400000, phy_addr = 0x56400000
7 th virt_addr = 0xc6600000, phy_addr = 0x56600000
Driver 'sd' needs updating - please use bus_type methods
S3C NAND Driver, (c) 2008 Samsung Electronics
S3C NAND Driver is using hardware ECC.
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit)
Creating 4 MTD partitions on "NAND 1GiB 3,3V 8-bit":
0x00000000-0x00080000 : "Bootloader"
0x00080000-0x00400000 : "Kernel"
0x00400000-0x03400000 : "Rootfs"
0x03400000-0x40000000 : "File System"
 楼主| suseng777 发表于 2010-11-18 14:47 | 显示全部楼层
搞定了,原来是时钟设置问题
