[产品供应] MAX8727ETB+T绝对价格优势
3846|0
 楼主| renaly 发表于 2010-11-10 12:55 | 显示全部楼层 |阅读模式
ip, tc, hz, AC, AD
深圳市洪源电子有限公司
http://china.alibaba.com/company/detail/szhongyuandz.html
0755-83651607 罗智
型号
TLE1010-r25cn
HM00-04597LF
P11711.142NLT 1.4UH
PF0465.502NLT 5UH普思
PG0437.601NL 0.6UH 18A
PF0560.382NLT 3.8UH
PG0006.312NLT 3.1UH
HMU1370-5R0-R 5uh
HM66-70100LFTR13 10uh
NHL7022FR-100M
SRSQ104-5R2N CHOKE 5.2UH 30% 5.5A SRSQ104-5R2N
SRSQ104-2R2N CHOKE 2.2uH 30% 8A 0.015R 10.3*10.4
FDV1040-2R2M=P3 COIL INDUCTOR 2.2UH 20%
DTVS205ER201A
DTVS205EH201A
G6J-2FL-Y-DC4.5, SMD
BRS-1534P08
E-57S08CN
KR-292-01
DSX321G-25M-9PF
KSX-35-19500K8A-QD0R
TAS-3225A 26mhz
TAS-3225A 40mhz
CXC6X260000GHVRB02帕特仑
NX5032SA 13.580625MHZ
H130B-40.000-8-NS2
NX5032SG 40MHZ
NX5032SG 40MHZ
9C49300012 XTAL 49.3811MHz 30ppm 12PF
LFB2H2G60BB1B973 3.5G
LFB312G45SW1A626
DFCB25G80LBHAB 5.8G
DEA165375BT-2121A1
BP22SQ001AR3 DBF 2.4GHz
04023J0R2ABSTR Accu-P
SAFC926.4M
V1311AZ0867
EFCH1960TCA1
EFCH881MTCA1
EFCH942MTCA7;5V;50Ω;942.5MHZ;100NH
EFCH1842TCA7;5V,50Ω;1842.50MHZ;15NH
B39182-B4133-U510,EPCOS,
B39182-B7721-C910;1842.5MHz;EPCOS
B39182-B7821-C710
B7821 942.5MHz
B7822 1842.5MHz
B39182-B7852-K410-S09
B39202-B7825-C710-S09 1960MHz
B7825;EPCOS
B7826 1960MHz
B39202-B7851-K410,EPCOS,
B39371-b3677-u310 BALUN
B39941-B7820-C710 942.5
B39941-B7837-K410,EPCOS,
B39941-B9401-K610
B39202-B9403-K610
B39182-B9402-K610
B39881-B9400-K610
WF755G0942PD;942MHZ
WF754G1842PD;1842MHZ
856409;1842.5M;1.5dB;2.0;CSP6;
856387;942.5M;1.5dB;1.9;CSP6;
FAR-F5EA-942M50-D27F;942MHZ;50Ω;-30+85℃
FAR-F5EB-942M50-B28E FOR FILTER SAW 942.5MHz EGSM900  5PIN
FAR-F5EB-881M50-B28Z FOR GSM LR FILTER SAW 881.5MHz  5PIN
FAR-F5CP-836M50-D203-J
FAR-F6EA-1G8425-D2ABA;1880MHZ;50Ω;-20+65℃
FAR-F6EB-1G8425-B2BG;DCSband(5-pin;)
FAR-F6EB-1G8425-B2BG  FOR GSM FILTER SAW 1842.5MHz GSM1800
G6KE-1G8425-Y4QG-Z    3000
SAFEH942MFN0F00R002.6dB;50/150Ω;SMD-10/85C;
LFB182G45SG9A213
LFB182G45SG9A293
SAFED1G96FA0F00R12
SAFEH1G96FB0F00R00
TFS924B
ALA621C4
PA1575mz50J4G-15-16 1.589MHZ 15%15*4
PA1575MK4G-182-21)
GPS132N-S3-00-A21.5*15*6.5m
PA502FMG
PW3078Z
LMG-003S-5101A
LM-T615S3-C
LM-D615S4-C
HWXN304
HWXR571A
HWXP641-1
CXG1189AXR
SHS-M090TK,
D1016 M034G+
EFSD836MD2S2 PANASONIC FOR  SAW LTCC 836.5/881.5MHz  13PIN
CWA2-1000-10-TYS1 TF-PWR ASSY;1000W,CWA2-1000-10-TYS1,S1E,COLDWATT,1KW-RL,SINGLE 12V PSU
P2M-6600P ASSY;600W,B001150016,ZIPPY,2U SINGLE POWER SUPPLY
MS-156NB
MHC-310
MHC-188A TACT TP
CPU775  775 cpu插座
DMM9-S240fc-1N-FC(t)DDR2,240P,1.0MM,ST,H14.45MM,
DDR2,240P,1.0MM,ST,
DVI&D-SUB(2 IN 1) R/A DIP15 G/F
DVI-D DIP24 1241-440-1E4-3B GOLD3u"
DVI-D DIP24 1241-440-1EJ-3B Gold3u"
HDMI DIP19 R/A 5300-519-091-E1 GOLD
QT800121-1110SR-F
BTBM5-02005-TP21
BTBF5-02005-TPF1
BTBF5-S1005-TPF0
BTBM5-S1005-TPF0
SM-JAK06-005
5602(CON24 5602 024 000 829 SMD24PIN P=0.4 Height=1.5mm Board To Board)
QT012003-1120J-8F BTB HD SMD2*100 P=0.5MM
AEA-BTB-023-T80 BTB HD
B-C CONNECTOR DIP4 1.25mm TIN R/A L/F
B-C CONNECTOR DIP2 1.25mm TIN R/A L/F
CONN B-F 7151-E15N-00R P=1mm R/A TIN
CONN W-B SMD2  P=1.25mm R/A TIN
CONN W-B SMD3P  P=1.25mm R/A TIN
CONN SMD30 GOLD AFN300-N2G11 P-TWO
88503-4001
FC25608-AP
FPC DIP15 R/A P=1mm 5F2.2426B TIN
254001MB003G205ZR 3P P2.5 TP
SM-BAT03-003
HB-2P003S-Z000 TP
P2035-62
HB-2P003S-Z000 TP
100002PR004G216ZL
100002FR008G215ZL
SS-6446-NF-OST
3010655800 DIP8 8P8C GOLD 6U
EPJ1-5-A-T
AR-616E4-50-CON'N 4P
AR-616MS4-50/170-M3 4P4C
AR-616MS4-50/170-M3 4P4C BK
AR-616PF-4 4P4C BK
MJ-616E4-70-CON'N
KPJ2547-D6-SMT TP
TC18-013-22 BK
JACK 1*3 JR11030(Y/W/R) R/A DIP6/F
JACK 2*2-1 R/A 5105-855-272-C6 DIP5
RCA JACK 2*2-1 DIP5 5J1.2411E-14466.203
Ph.Jack 5J1.2C11F-21126.104 DIP5 (Black)
JACK 5102-E6R-022-52 DIP5F
JACK R/A DIP9 5104-002-323-61
R7235-BNDT 高频插座
TNC-800T  高频头连接器
Ph.Jack 5102-B4R-022-52 DIP5(Black) TK
Jack 5102-B6R-022-52 DIP5(Lime)
2DC-0005D100 DC POWER JACK D=2mm
CONN SMD5 R/A WAFER P=1.0mm TIN ARC
CONN DIP16 R/A 5W1.2521B-11400.116 TIN
CONN FEMALE R/A DIP8P P=2.54mm G/F ARC
CONN FEMALE R/A DIP8P P=2.54mm Brass
CONN DIP16 R/A P=1mm 7101-E16N-00C TIN
CONN DIP16 FEMALE P=2.54mm R/A G/F L/F
CONN USB B TYPE DIP4 BLACK R/A GOLD
CONN USB B TYPE DIP4F 30U GOLD ARC
10031567-001CLF ASRECEPTACLESMD29P30UGOLDCAP
10029065-001CLF ATARECEPTACLE22PSMTGOLD
SASF3112672TR ASRECEPTACLE29PP=1.27MM15UAU
SATA-111-0165-2 ATA7+15PSMTRECEPTACLE15uAU
SASF313-018-1-C ASRECEPTACLESMT29P0.76UM
TFRHS-00815-TP00
WKUB1015-011
NOTOO31600
YSMA2021R
GCA263B-6S-H22
SIM-CARD-180
SKRKAHE010
HEAT SINK 28*28*7.9MM散热片
Heat Sink 28*28*7.9mm散热片
HEAT SINK 7.5*7.5 mm散热片
Cable Assy 2*4P L8 76mmLIPS AD数据线
GPS129N-N3-00-A
LS20023
GPD14B01
CST-DT60A-IM
ISDB-T TM001
MA820
DFBM-CS320-FI1R 50Ω INTERFACE USB  DELTA FOR
QBTM300-01V
Wireless 3945ABG-MoW 2
4965AGNMM1GN
MP-RC102BULK/809
MD560(B)
WM3B2915ABGEU
WMP-G09
LR802UWG-1A2
SSK-ALLIN1-0533
QBTM300-01V
QBTM400
DMD2022IN
WLG-1801
WM3236AQ
APM6828
BTTM46C2SA
SWL-2455C/S
WLAN6064EBC3-HL MODULE
LC6311+
MCIMX357DJQ5C
BA3842F
TA8493AF
NT68521AXF
DA82562EM
SAA7185
RG82845E
RG82845G
RG82845GV
AD8091ART-REEL7
2SC5065-Y
A276308-70
MAX3160C
ST93CS46M1
TL431C
LM1877N-9
16410BA(4UC-51-IF5B)
PCD50953H/E82
2N5064
ADD8704ARUZ
RTQ035P02
BAV99TA
BJ8P156AP
SJ2313L
RFCMF3216090M1T 1206
XTAL 32.768KHZ 20PPM 6PF ECX-306
MM1615A
NC7S08M5X
NJM2125F
BAW56-7-F
AO8822
MSQA6V1W5T2
LB1233M-TLM-E
74HC4066PW
02L1537(IBM)
PM49FL004T-33JCE 512k
AO6408L
AO3411
TDA7448
MA3X15800L
2N7002VA-7
NH82801GR/SL8FY
JG82852GME/SL8D7
TL16C550DIRHB
MAX1683EUK-T
MAX1683EUK+T
DS1810R-10
IDTQS3VH126Q
SCH5017-NW
ISL6307CRZ
ICS932S401EGLF-T
ICS9DB108AGLFT
OTI2168IT-G-B6
ICS952601EFT
ISL6565BCRZ
ISL6605CRZ
NC7S86P5X
PCA9515ADP
NC7SZ384P5X
PI5A127UX
HIP6521CBZ
DS1813R-15
IRFR3707Z
IRFR3709Z
AO4824
CEB6030L
MBRA210LT3G
SW300
MTV512GMV
RTD2523
BJ8P156AP
fm-2138sc-5cn
SI2319DS-T1
SI3433DV
CAT24C16WI-GT3
L1117D-ADJ
at24c16an-10si-2.7
lqc3225f-1r0ma-a01
lqh43mn220k03l
XC6201P302MR
XC6404FV12MR
DTC115EUA
BAS16E6327
NT68523XFG
UPD61521
RF3140
vou1810f28twc
2sd1898
rb425d
pap1301bm
R5323Z027B-TR-FD
UC3845AD8TR
RTD2523
IT8213F/AX-L
LC4064V-75T44
PEF4268T-V1.2
HT46R22
HT46R12
HT48R062
HT48R06A-1
HT48R06
HT82V736
HT45R04E
IHT935
16C550
SPLC780D-001B-C
PM49FL002T-33JCF
FM1182E-GE
BD8211EFV-E2
MC68B09CP
MC68302FC25
T6TN2XBG-0004
CXA3562AR
RJ21V3BBOET
RJ23T3BA1FT
LM4990ITLX/NOPB
1ps79sb30
IR3Y29B
CY7C1009B-20VCT
TPS72518DCQR
vou1810f28twc
2sd1898
rb425d
RF3110TR13
LTC4006EGN-6#TRPBF
MAX211ECAI+
XC9116B02AMR
SAFSD1G84FA0T00R12
W9812G6IH-75
STAC9227X5
S29AL032D70TFI030
B39182-B7852K410-S09
RF3166
MT6305BN
AT1453BP_PBF
SFECF10M7FA00-R0
SSM6N16FE(TE85L.F)
UPG2012TB-E3-A
QT1080-ISG
BP22SQ001AR3
LTC1844ES5-3.3#TR
PEF4268T-V1.2
BAS16E6327
G920CT24U
TS5A23159RSER
ATR0610-PQQ
TWL3025BZGMR
TRF6151CRHJR
D751992AZHH
WT6702F
Glamo3362
AAT1275IRN-5.0-T1
SM8121AH
VSN1005X09NR151
LMG003S-5101A
HWXP641-1 TB1208
DS2119ME+T&R
RU82566DC
SSX35BCB
R5531V002-E2-FA
LMC6032IMX
AK2001
LM63DIMAX
HYB25DC512160CE-5
P89LPC932A1FDH
STTS75M2F
SPX1004AM1-L-1.2
TPS3801K33DCKR
MX3000CS
04023J0R2ABSTR
GRM1555C1H101JD01E
AUO-003K6
NX5032SG 40MHZ
S29AL032D70TFI04
ADSP-21062CS-160
CXG1189AXR-T9
PCA9515ADP
USB3316B-GJ-TR
LFB312G45SW1A626
FI-RE41S-HF-R1500?
G6J-2FL-Y-TR?
LT3481EDD#TRPBF
0451003.MRL
SAWEN1G84CB0F00R12
AAT3169IFO-T1
AAT3151BIWP-T1
SC32442B43-7081
CVGB260A 26.000MHZ
SLDA52-2R710G-S1 ?
SLDA52-2R540G-S1?
UH7843Q
SFR881PY001
EL2244CSZ
P89LPC932A1FDH
UH7843Q
SLDA52-2R710G-S1
SLDA52-2R540G-S1
RTL8201CL
FCX-05 26.00MHZ
PIC18F63J90-I/PT
S-8261AAJMD-G2JT2G
FC7710
AAT3169IFO-T1
AAT3151BIWP-T1
SAWEN1G84CB0F00R12
SFR881PY001
FDC604-NL
EL2244CSZ
04023J0R2ABSTR
G6J-2FL-Y-DC4.5
LTC1733EMSE#TRPBF
PIC18F63J90-I/PT
NX5032SG/40MHZ/10PPM/8PF
AUO-003K6
CT8930-SAS
IP178C
SIL9030CTU
CT1975-SAM
MAX1771CSA+T
CY62256LL
MC13191FC
TPA3100D2RGZR
88SE6101-NNC1
88SE6145-TFE1
STAC9271X5T48E-CA2
R5323Z027B-TR-FD
MC9328MXS
TMS320DA255ZHH
LT3481EDD#TRPBF
PI2PCIE412-CZHEX
PC82562V
VT6210L
PCM2705DBR
UC3845AD8TR
LC126A
RTD2523
IT8213F/AX-L
PIC16LF88-I
PMB2520
PM30CTJ060
LR645N5
PM6650
PM6680 LINE
PMB6812V1.62
L4973V5
L5991D013TR-2
L9826
VNQ830
USBUF01W6
TSH70CLT
CAT3604HS4-TE13
CAT7581CA
SC464AYB
SC434623CDWR2
SC406256CDWR2
MC145017P
MC14467
MC14468
MC145167P
MC33078DR2
MC3335P
MC34164P-003
TS5V330DBQ VIDEO SW  TI
TPS105124
TPS2216DBR
TPS2211AIDB
TPS3801K33DCKR
TPS61010DGSR
TPS62200DBVR
TPS62208DBVR
TPS7148QDR
TPS78601DCQR
TPS71918-12DRVR
SN105124DGSR
TL2845-33M
TL38C43
TL7705ACDR
TLV2217-33K
TLV5535PW
BQ2057CTSTRG4
BQ24022DRCR
BQ24022DRCR
MM1615A
mm3177fnre
MB3769A
MB3776A
MB3800PFV
MB3878pfv-g-bnd-er
MB3887FV-G-BND-ER
FA13843N-TE1
FA5501AN-TE1
FA5502M
R1110N251A-TR
R114Q181D-TR-FA
R3111N271
R3111N201A-TR
R5426N108CA-TR-FA
R5531V 260'C
R5426N120CA-TR-F
RV5C386A
RN5VL28AA-TR
RN5VT111AA-TL
RN5VT10CA-TR
RN5VD40AA-TR-F
RS5RM4018
RH5RE40AA-F
RH5VL23CA-T1
S-1167B33-16T2G
S-80736SN-D0-T1
S-80828ANNP
S-80830SN-DT
S-80833cnmc-b8s-t2
S-80835AMNP
S-80836CNMC-B8V-T2G
S-80922CNMC-G8S-T2
S-80923CNMC-GBTT2G
S-81112B32MC-L6R-TB
S-81215SG
S-81216SGUP-DQP-T16K
S-81224sgup-dqx-t1
S-81235SG-QI-T1
S-81333HG-KF-T1
S-814A33AMC-BCX-T2
S-8261ABRMD
S-8323C27MA
S-8328B33me
S-8333ACBC-T8T1GF
S-8333ACBC-T8T1GF
s-8354a27mc-jqmt2g
S-8520B18MC
S-190V13
ADP1653ACPZ-R7
ADP3120JRZ PWM
ADP3121JCPZ-RL
ADP3168JRUZ-REEL
ADP3188JRUZ
ADP3207A0091CPZA
ADP3208JCPZ-RL
ADP3209JCPZ-RL
ADP3611JRMZ-R
ADP3806JRUZ-12.5-R7
HIP6012CB PWM CTL
HIP6302C6Z-T
HIP6521CBZ
TLE6263
LT1004LS8-1.2-T1
LT1009CE
LT1304cs8-3.3v#tr
LTC130433
LT1117CST#PBF
LTC1693-1IS8#TRPBF
LTC1844ES5-3.3#/tr
LT1725CGN
LTC1733EMSE#TRPBF
LTC1772BES6#TR
LTC1923EUH#TRPBF
LT1931ES5
LTC30433
LTC3406ES5#PBF
LTC3406ES5#PBF
LTC3417EDHC#TRPBF
LTC3417AEFE
LT3467ES6#TRPBF
LTC3713EG#TRPBF
LTC3727EG-1
LTC4006EGN-6#TRPBF
LTC4055EUF
LTC4211CMS#TRPBF
MAX548
MAX693ACWE
MAX810
MAX1115EKA
MAX1505XETM+T
max1508ETA+T
MAX1543ETP
MAX1565E
MAX1683EUK-T
MAX1683EUK+T
MAX1686EUK-T
MAX1801 2.7V
MAX1858EEG+T
MAX1904EA1-TG074
MAX4614csd
MAX4614CUD
MAX4889ETO+
MAX6328UR26
MAX6423XS16
MAX8561ETA+T
MAX8728ETJ+
MAX8761ETG+
LM2575T-5
LM2612ABPXNS
LM2664
ISP1105W
TL2336ML
MCZ33880EWR2
ST7533-0D-G
P89C669FA
ZJYS51R5-M4PAT-01
TSOP34856
CY62256LL-70ZXC
LM5642MTC
AD8356A-KG
NJM2058V(TE1)
M30624MGP-332GP
UPD703249YGC-123-8EA
LC723781N-9D22
BA7654F-E2
BA6920FP-Y
YELQ10S680M
AN2546FH-A
CS51412EDR8
S29AL008D70TFI02
ADP2108ACBZ-1.5-R7
SKY13276-334
FHW0805UC4N7KGT
CM2545X171R-10
SP3238EEA
500027-2481
MAX8727ETB+T
SIP-2290HD
ML414R-TT40A-TP1
SN65HVD3082EDR
MAX8727ETB+T
RT9939GQW
个人签名:深圳市洪源电子有限公司 http://szhongyuandz.cn.alibaba.com 0755-83651607 罗智
